Good Deal Not Good Deal
I'm looking at a 94 F250 XLT 7.3l DI Factory Turbo 5spd 4x4 with 97k on it and the owner mentioned a small oil drip Not enough to notice from oil change intervals 3-5k or leave a spot on the driveway. But it is coming from the rear main seal. Not knowing too much about diesels except for the fact at 97k the diesel hasn't even broke in yet.
Is there anything I should be looking for specifically. Asking price isn't bad either 8k.
Any knoledge is greatly appreciated as always!!!!!!!!!!!!!!
this is a quote from a well known guru of our trucks:
despite the low mileage, i'd talk him down if all of this looked good.
Originally Posted by steve baz
BuyingUsedPowerStrokeDiesels
ThingsToLookForWhenBuyingAUsedPowerStrokeDiesel
Turbo:
You might take the air tube off the back of the air filter and look inside of it. If there is dirt build up, that is a very bad sign, so are the turbo fins looking sand blasted or bent. A little oily film is normal since the valve cover breather exits inside the tube.
Airbox:
Check the two bolts holding down the airbox lid. If they are plastic with a square recess, it is a recalled part. The recall is expired, but without the updated lid the risk of dirt infiltration is greater, the lid was updated with more supports and the updated bolts are metal with a straight slot. If it is the old style, you spend around $80 to update it.
Tranny:
If you buy a truck with an auto tranny, finding out if it's been maintained is essential, as the E4OD is an expensive transmission. Also, (if auto) seeing if the truck has an auxiliary transmission cooler would be worthwhile. For sticks, listen for clunking when shutting off or small vibration while operating. It could be an indication of a dual mass flywheel going out. Many have replaced them with single mass units.
Rear Gear Ratio:
4:10 will pull better, get slightly lower mpg’s and run a higher RPM compared to 3:55.
Coolant:
Ask the previous owner about the coolant - have they been adding FW16 or DCA4 to keep a proper SCA level? It is very important for stopping cavitation. You can get test strips to check the SCA level from NAPA, International, or Ford. I would test the current condition while looking over the truck, the SCA level should be between 1.5 and 3.0. Also, see if it has a block heater (it was an option on 97's).
Front end:
Check the front end for wear, or have an alignment shop check out the ball joints and steering linkage (tie rod ends). If they are shot, it is spendy (all four tie rods are around $400 just for parts, ball joint labor is also very spendy)
Oil:
The questions to ask are how often the oil was changed (at least every 5,000) and what kind of oil they used (diesel rated)? An oil analysis could tell you if there might be an engine problem or not.
Aftermarket stuff:
Seeing if the truck has got an aftermarket downpipe would be nice, a chip, or gauges (pyrometer, trans temp, etc.). Ask about any added items and who installed them.
Glow Plugs/Relay:
Find out if the glow plugs are in good working condition as well as the relay. Ask if either has been changed and when. You can check the glow plug resistance through the valve cover connector if needed (http://forums.ford-diesel.com/cgi-bi...&f=21&t=005210), and the relay should have power to both large terminals on top when the key is turned on, and one of the terminals should go out before ~2 minutes.
Injector o-rings:
The injector O-rings have been known to be a problem. The new o-ring sets have a pink middle seal. If the truck has an o-ring problem, one of the signs can be a discoloration of the fuel in the filter bowl. There is a drain on the passenger side front of the filter bowl for draining water (the filter is also the water separator) and you can catch some of the drained fuel in a jar – it should be dingy yellow and not blue or dark.
Leaks and Drips:
You can check the valley between the heads of the V8 for moisture and/or fluid. It should be dry not wet. Most leaks will run through this valley and down the back of the motor dripping off by the tranny/engine coupling.
VIN number:
If you take the VIN to any dealer, they can tell you when it was built, when it went into service, and some of the work that might have been done on it. You can also run prospective VIN's through Carfax.com to see the title history.
Turbo:
Airbox:
Tranny:
Rear Gear Ratio:
Coolant:
Front end:
Oil:
Aftermarket stuff:
Glow Plugs/Relay:
Injector o-rings:
Leaks and Drips:
VIN number:
BAZ's PAGES. Home Page
Surprised you havent seen the page... he's not the best at internet, but he has a lot of good stuff on there, if you have time to read it all.
Guru may have been overstepping, but "Excellent compiler" is most definately suiting...
Thanks you both for the info. The truck drove nice n smooth as it should for low mileage diesel. Drove up from Greenville SC to Eastern VA est. 17 mpg 70-75 and 23 mpg 55-60 mph with an aluminum cap on the back plus keeping rpm's down near or a little above 2k helps alot!!!!!!!!!!!!!!!!
So now I'm a Proud owner of an F250 4x4 ext cab 8ft bed 7.3L Turbo Diesel.
Also went to a truck n tractor pull lastnight in Elizabeth city NC
Oldguyfl
11-02-2015 06:38 AM
michaeloac
13
08-30-2008 11:29 AM
medeek
02-28-2006 09:22 PM
