Sponsored by: Real Truck
tail gate not opening
Old Aug 12, 2008 | 01:13 PM
bohiaa's Avatar
bohiaa
hay all:
as some of ya know I just got a new TO ME 2000 F250 2000
it seems that the tail gate wont open, I read the owners manual it said the same key to start the truck will unlock the gate, however it seems like it's locking it but NOT unlocking it, I figure the rod is off inside the gate itself.
Wondering if anyone has any experance with this and how do I go about it ?
Thanks
Old Aug 12, 2008 | 01:38 PM
bohiaa's Avatar
bohiaa
issue resolved.......
I had a rubber type bed liner that's screwed on. I pulled that off and sure enoulf I seen how to get to the latch. it looked like it just needed some wd40.
all is well.....
Old Aug 12, 2008 | 08:18 PM
dave-b's Avatar
dave-b
I have had a little trouble on a couple of mine. Squirting some WD40 up there always fixed the problem, too.
Old Aug 13, 2008 | 07:22 AM
Dukernc's Avatar
Dukernc
I also had a similar problem on my 99' where it would bindup and be very hard to open. I took off the access panel and found the connecting rods to be binding and little bent up. Figured that was more than likely the problem so I adjusted the rods and sprayed some white lithium grease on all the contacts points. No more problems. Also decided to do the same thing on my 90' and do a little pm on it too. Both tailgates are working very smooth. Good Luck!
Old Aug 13, 2008 | 06:44 PM
Beerstalker's Avatar
Beerstalker
Try not to use WD40 or any other liquid lubricant in your lock cylinders. They tend to gather dirt and dust and just make things worse after a while. Most car part stores sell little tubes of graphite for lubricating the lock cylinders, that is what you should use.
Old Aug 13, 2008 | 07:14 PM
89CrewCab's Avatar
89CrewCab
Put one hand on the top of the tailgate and the other on the handle. Push forward on the tailgate while lifting on the handle.
Don Baggett
2009 - 2014 F150
Jan 1, 2015 06:08 PM
tenptbuck7mmmag
1997 - 2003 F150
13
Oct 18, 2007 08:34 PM
Rushmore X
Apr 10, 2006 03:33 AM
s9bryant
1997 - 2003 F150
19
Mar 9, 2005 11:44 AM
seahawk31
1997 - 2003 F150
Feb 1, 2004 09:00 PM
