magnetic guages
Old Mar 19, 2002 | 10:32 PM
Mil1ion's Avatar
Mil1ion
magnetic guages
Old Mar 30, 2002 | 12:04 PM
pcouncilor
Guest
Posts: n/a
magnetic guages
Hey, I'm trying to figure out whether my engine temp guage and my fuel guage are working (neither is registering). Is there any way to test them with an ohmeter/voltmeter (which is what I have)? The guages are on a 92 Explorer. Any help would be appreciated!
Old Mar 30, 2002 | 08:27 PM
lshort's Avatar
lshort
magnetic guages
I have not worked on anything as new as a 92 but on older ones you can
take the wire off the sender and ground it and if it pegs the gauge the gauge is ok.I think this will work on yours.Is this one of those
that you have to replace the gauges in pairs on?Hope this helps
Larry
Old Mar 30, 2002 | 10:40 PM
nitro94's Avatar
nitro94
magnetic guages
Fuel guage testing. Install in place of sending unit 10 ohms resistance from guage wire to ground with key on. Should read full or above by 2 pointers width. Install 73 ohms resistance. Should read empty or below by 2 pointers width. Temp guage, 10 ohms is hot, 73 ohms is cold.
Old Mar 30, 2002 | 11:46 PM
PhilC's Avatar
PhilC
magnetic guages
Hey guys, thanks for the information. I hope this doesn't seem to silly, but I'm new at the electrical end of things and had a couple basic questions. 1.Is the resistor just a piece of wire with a certain resistance, or is it something I need to pick up at the parts shop. 2.Do I have to attach the resistor directly to the battery ground, or will the frame of the vehicle do. Thanks again!
Phil
Old Mar 31, 2002 | 10:51 AM
nitro94's Avatar
nitro94
magnetic guages
The ground can be any convenient location. I have a tester ($150) that will dial in 0 to over several thousand ohms. For a one time test try Radio Shack for the nesessary resistors.
Old Mar 31, 2002 | 05:31 PM
PhilC's Avatar
PhilC
magnetic guages
Thanks for all the good info.!
Phil
Old Apr 2, 2002 | 01:50 AM
PhilC's Avatar
PhilC
magnetic guages
One more thing ...
I got the instruument cluster out and there is a harness that plugs INTO the cluster. There's no wire to ground! What should I do?
Phil
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
