Oil Change
Old Aug 11, 2008 | 06:24 PM
skyhawk72's Avatar
skyhawk72
Oil Change
I keep reading where people say you have to fill up the oil filter on the new f150 before replacing it. Does anyone do this? Is it really neccacary?
Thanks for the help,
Will
Old Aug 11, 2008 | 06:29 PM
rebelyell618's Avatar
rebelyell618
i have NEVER read that you have to, it is just a feel better thing to do, knowing oil is already there upon start up.
i do it on all oil changes on my vehicles.
Old Aug 11, 2008 | 06:39 PM
skyhawk72's Avatar
skyhawk72
so with a motorcraft filter is there some special way of filling that i need to know about?
Old Aug 11, 2008 | 06:51 PM
RISUPERCREWMAN's Avatar
RISUPERCREWMAN
How do you fill up a oil filter with oil, when the filter mounts sideways? It will make a mess!.............
Old Aug 11, 2008 | 07:00 PM
skyhawk72's Avatar
skyhawk72
Thats another thing ive been trying to figure out!
Old Aug 11, 2008 | 07:20 PM
rebelyell618
it is mainly done on motors have vertical filter mounts not horizontal (ie the 5.4 in my sig). that proves what i mean as a feel good action it isn't a necessity to fill the filter prior to installing.
look at the oil filter with the gasket up and the hole you see where the threads are cut into, just pour the oil into there and screw the filter on.. nothing special
Old Aug 11, 2008 | 07:44 PM
FTE Ken's Avatar
FTE Ken
I fill the filter about half-way on my F150 and it doesn't spill. It helps reduce the amount of time the engine is running without oil pressure - same reason the filters have an anti-drain valve.
Old Aug 11, 2008 | 07:59 PM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
in one steady motion, pour oil into the new filter until the oil level reaches the top
let the oil drain down. you'll be about 1/2 full. screw onto engine and fill it up
I agree with Ken. get as much oil as you can into the filter. motor will spend less time dry spinning before the oil starts getting pumped
Old Aug 11, 2008 | 08:49 PM
Frd67cobra's Avatar
Frd67cobra
Yeah, I fill mine about halfway. You might slop a little by the time you get the threads to catch, but no biggie. That's what that little drain tray is for. Just don't rev it on startup till you build pressure.
Old Aug 11, 2008 | 10:10 PM
JoSHN's Avatar
JoSHN
On my 97 f-150, it had a relocated oil filter.
Apparently it came in a kit to help change it easier.
I bought the truck second hand, so I have no idea where it came from.
Does anyone know if there is one for the new 5.4L?
Old Aug 12, 2008 | 10:03 PM
Svets96's Avatar
Svets96
Isn't there a way to build oil pressure in the system before startup? What I'm tryin to say is the trick like turning the key to the on position and put accelerator to the floor while turning the key which turns the engine over (but doesn't start) until you get oil press.? Correct me if I'm wrong.??
Old Aug 12, 2008 | 10:18 PM
Frd67cobra's Avatar
Frd67cobra
Yeah, you could do that, that's the correct procedure. But I don't bother with all that, I just fill the filter about halfway and fire it up with no throttle, with some oil in the filter these motors build pressure quick enough.
Old Aug 13, 2008 | 11:24 AM
Slvr 2008 SS SC's Avatar
Slvr 2008 SS SC
I've done oil changes on several different vehicles and never tried this before but; if you left the filter off and filled your engine with oil, wouldn't the oil spill onto the ground because of the lack of a filter?
Old Aug 13, 2008 | 03:19 PM
mordecai22's Avatar
mordecai22
I think you are misreading. You don't leave the filter off.
Old Aug 13, 2008 | 05:13 PM
Slvr 2008 SS SC
It's not that I misread anything, I know you don't leave the filter off. What I'm trying to ask is, "if" the filter was left off when you filled the engine with oil, oil would leak onto the ground. Therefore with the filter on oil would naturally fill the filter. That is unless, with the filter on, it creates some sort of bubble that prevents the oil from soaking into the filter. Then when the engine is started and the oil pump forces the oil to flow through the filter. So is it really necessary to fill the filter?
