ticking
Old Aug 11, 2008 | 01:04 PM
red7.3F350's Avatar
red7.3F350
Question ticking
I have developed a ticking sound around 1300 to 1600 rpms. doesn't do it at idle, no blue or white smoke. Did a buzz test, and ran for codes. Nothing came up. Any ideas of what this could be?
Old Aug 11, 2008 | 01:57 PM
clintbonnie's Avatar
clintbonnie
My guess would be #8 injector click.. Mine does it specially when not using biodiesel.. And a Big welcome to the forum..
John311t's Avatar
John311t
what year is your truck?
Old Aug 11, 2008 | 06:26 PM
red7.3F350's Avatar
red7.3F350
it is a 1999.5
Old Aug 11, 2008 | 06:27 PM
red7.3F350's Avatar
red7.3F350
168000 miles
Old Aug 11, 2008 | 06:37 PM
ron's power stroke's Avatar
ron's power stroke
you mean an exhaust tick sound??? if so..check the tube.(looks like a brake line) on the passanger side exhuast manifold..near the front of the truck....this tube goes up to the EBPS (exhaust back pressure sensor)..it will some times get pin holes in it and start to tick.....
Old Aug 11, 2008 | 07:46 PM
greedy737's Avatar
greedy737
Welcome to FTE!! Could also be an uppipe leak. Look for black soot at the dounuts!
Old Aug 11, 2008 | 08:58 PM
PaysonPSD's Avatar
PaysonPSD
If you get this ticking while sitting and revving to 1300-1600 have someone do the skinny peddle for you while you try to locate the ticking with a mechanic's stethoscope. No stethoscope - use a long skinny funnel held to your ear. Hey, don't laugh , it can help you narrow it down to a particular area. But be careful. You don't want to go deaf. If you go deaf in one ear do not use the other ear.
Old Aug 12, 2008 | 04:38 PM
red7.3F350's Avatar
red7.3F350
yea I checked the whole exhaust for leaks, and I can't find any signs. I only hear it when I'm under load. it doesn't do it when I am parked. if i floor it i can't hear it but if i accelerate normally then it is most noticeable. is this an injector going? wouldn't the buzz test show that? could this possibly be a clutch issue if the sound isn't there while under no load?
Old Aug 12, 2008 | 04:39 PM
red7.3F350's Avatar
red7.3F350
its definately on the drivers side and it sounds like it is coming from behind the dash/firewall.
Old Aug 12, 2008 | 06:54 PM
PaysonPSD's Avatar
PaysonPSD
Are you able to do a CCT, Cylinder Contribution Test?
Old Aug 12, 2008 | 06:56 PM
greedy737's Avatar
greedy737
did you check the two exaust pipes coming up behind the motor to the turbo for leaks? there called the uppipes..
Old Aug 12, 2008 | 07:10 PM
AustinS's Avatar
AustinS
I'll bet the sound you hear is the #8 injector. This doesn't mean it's failing. Mine makes more noise at times than others and has for the last five years and it still runs just fine.
It is a different injector than the other seven, so it's bound to sound differently in operation.
Austin
