Disc Brakes
Old Aug 11, 2008 | 10:37 AM
Rebel Warrior's Avatar
Rebel Warrior
Question Disc Brakes
I would like to know which Master cylinder / brake proportioning valve I need to use on my truck to change the rear brake to disc? since the truck has a 14bolt GM rear axle the swap is easy. its just i dont really want to use an adjustable PP valve if I don't have to. any suggestions?? oh I read a lot of the post on this forum with little or no help. let get technical. Oh the only reason it has a 14 bolt is the Dana 60 was shattered from some hard wheeling. a quote from the previous owner.
Old Aug 11, 2008 | 11:13 AM
hairyboxnoogle's Avatar
hairyboxnoogle
well you could always just try yours and see what it does..
Old Aug 11, 2008 | 12:31 PM
Rebel Warrior
heads
I don't know about the heads yet but I think their about 75 -80 #s each arent they?
Old Aug 11, 2008 | 12:50 PM
Dirt racer's Avatar
Dirt racer
You could check with some of the sponsers here, but I know wild horses sells prop. valves set up for 4 wheel discs. Price is around a $100. I think you can use your same MC but you might have to remove a check valve inside the line that hooks to the MC for the rear. They are located in Ca. You could call them and see for sure.
