Glow plug switch
Old Aug 10, 2008 | 11:41 PM
DJOHNSTON78's Avatar
DJOHNSTON78
Glow plug switch
how do I put a cut out switch on my glow plugs on an 84 6.9L? Heck I don't even have a glow plug light on the dash.
Old Aug 11, 2008 | 04:58 PM
LCAM-01XA's Avatar
LCAM-01XA
Bottom right corner of the dashboard, in a black-face panel, that's where your WTS/glowplugs light should be, along with two others IIRC. As to how to wire a switch - without knowing what condition your system is, I'd suggest the safest way would be to disconnect the thin wires from the glowplugs relay on the passenger-side inner fender, then identify which one is the trigger one and which one is the ground, then connect the ground one back on, and run a wire from the terminal where the trigger used to go to the switch inside the cab, then run a wire from the switch to a key-on location in your fuse panel. This is what we did with my buddy's '86 F250, only because we used slow-glow AC Delco plugs that require to be left on for quite some time we also upgraded the stock relay to a much heavier-duty GM unit designed for said slow-glow system.
Old Aug 11, 2008 | 05:02 PM
LCAM-01XA's Avatar
LCAM-01XA
This should also help, courtesy of Zigg:
Old Aug 16, 2008 | 08:50 PM
DJOHNSTON78
thanks that will help alot
Old Aug 16, 2008 | 09:42 PM
Dave Sponaugle's Avatar
Dave Sponaugle
The only thing wrong in that picture is the wait to start wire is black with a pink stripe.
Small terminals are the ground and trigger wires.
Usually the ground wire is the one closest to the fender.
The trigger wire is usually closest to the engine.
If you draw power from a fuse that is only hot when the key is on, kids (large and small ones alike) can not turn the glow plugs on when the key is not on.
May save you from burnt out glow plugs or a dead battery.
Old Aug 23, 2008 | 10:36 AM
DJOHNSTON78
I was told that if you bypass the controller this way a guy hsa to put in some type of constant type of glow plugs and if you do what brand does everybody recomend.
Old Aug 23, 2008 | 02:34 PM
Diesel Fiend's Avatar
Diesel Fiend
Beru plugs are the way to go. And if you bypass the controller you will want to install a push button switch. Glow plugs are only supposed to be on for about 12 to 15 seconds before you start the motor.
Old Aug 23, 2008 | 06:19 PM
Dave Sponaugle
At 10 seconds glow time my engine starts just fine down to 0.
When it goes below zero, 10 seconds starts it and a second after glow of a few seconds keeps it running.
Old Aug 23, 2008 | 11:28 PM
LCAM-01XA's Avatar
LCAM-01XA
The ones you're thinking of are the AC Delco glowplugs for a '79 Olds 350 diesel, they are a direct bolt-in for our engines. They also have spade connectors, so they will plug in the harness as well. However, you will not need those plugs if you go with the momentary-on switch and keep the duty cycle to 10 seconds or less, so just install that and a set of Beru plugs and call it good.
Old Aug 24, 2008 | 04:54 AM
Dodge/Cummins's Avatar
Dodge/Cummins
That's what I did to my '86. Electric Golf Cart solenoid and 8 new Beru/Motorcraft glow plug and that hard starting B***H will start every time now.
I connected the glow plug wires off of the timer at the back of the motor together, passenger's side rear of timer moved over to driver's side front so they are directly connected.
Push button momentary switch with 3 amp in-line fuse wired to passengers side "small" post on timer. It's a "key on" power source.
Golf cart solenoid wired in to replace non-functioning factory one.
This motor WOULD NOT START unless it was 100 deg. or the block heater was plugged in. Like I said; now it fires up well.
One of these days I'll remove the timer completely as I don't like extraneous crap on my rigs for no reason. I wish every PO of every truck I've owned in the past felt that way. I've pulled enough junk, useless, burnt, leads-to-nowhere wire out of trucks and cars to last me a lifetime.
Jon143
13
Aug 1, 2017 09:24 AM
Garrett Killgore
Dec 1, 2016 05:07 PM
Watcher58
Sep 28, 2016 10:53 PM
mabc926
Aug 28, 2010 12:51 AM
MustangMatt96GT
37
Feb 9, 2009 11:57 AM
