Gauge install guidelines not in tech folder?
Old Aug 10, 2008 | 10:11 AM
Green_Monster's Avatar
Green_Monster
Question Gauge install guidelines not in tech folder?
Hey guys been doing my homework on a new gauge install and found good info and instructions around the net at sponsor sites.
I was just wondering if anyone( resident experts/techs)
would be willing to put some detailed instructions in there. Seems like this would be a great addition to the tech folder.
The pros and cons of diff types of sensors locations etc. Any tips at all in there would be great.
Old Aug 10, 2008 | 07:47 PM
Sarge261's Avatar
Sarge261
Is there anything that you specifically need help with or just looking for someone to post a sticky in there. I have done the guage install on quite a few trucks so if you need anything I can help...maybe.
Sarge
Old Aug 11, 2008 | 06:06 AM
Green_Monster
I was thinking of a sticky I guess. Seemed like some good basic info would be good to have in there.
I am planning on a 4 pod pillar mount boost, tranny, EGT ( pre or post turbo?) voltmeter or ????
Trying to find the time to get it done
Old Aug 11, 2008 | 06:29 AM
bismic's Avatar
bismic
EGT Gauges:
<TABLE style="WIDTH: 568pt; BORDER-COLLAPSE: collapse" cellSpacing=0 cellPadding=0 width=757 border=0 x:str><COLGROUP><COL style="WIDTH: 568pt; mso-width-source: userset; mso-width-alt: 27684" width=757><TBODY><TR style="HEIGHT: 12.75pt" height=17><TD class=xl26 style="BORDER-RIGHT: #d4d0c8; BORDER-TOP: #d4d0c8; BORDER-LEFT: #d4d0c8; WIDTH: 568pt; BORDER-BOTTOM: #d4d0c8; HEIGHT: 12.75pt; BACKGROUND-COLOR: transparent" width=757 height=17>EGT - pre-turbo: you want to put the EGT directly out from the last rearmost exaust port on the drivers side.</TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD class=xl25 style="BORDER-RIGHT: #d4d0c8; BORDER-TOP: #d4d0c8; BORDER-LEFT: #d4d0c8; WIDTH: 568pt; BORDER-BOTTOM: #d4d0c8; HEIGHT: 12.75pt; BACKGROUND-COLOR: transparent" width=757 height=17></TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD class=xl26 style="BORDER-RIGHT: #d4d0c8; BORDER-TOP: #d4d0c8; BORDER-LEFT: #d4d0c8; WIDTH: 568pt; BORDER-BOTTOM: #d4d0c8; HEIGHT: 12.75pt; BACKGROUND-COLOR: transparent" width=757 height=17>EGT - post-turbo: (install probe on drivers side exhaust manifold towards the rear)</TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD class=xl24 style="BORDER-RIGHT: #d4d0c8; BORDER-TOP: #d4d0c8; BORDER-LEFT: #d4d0c8; WIDTH: 568pt; BORDER-BOTTOM: #d4d0c8; HEIGHT: 12.75pt; BACKGROUND-COLOR: transparent" width=757 height=17>http://www.dieselmanor.com/diy/PSD3-gauge/image24.htm</TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD class=xl24 style="BORDER-RIGHT: #d4d0c8; BORDER-TOP: #d4d0c8; BORDER-LEFT: #d4d0c8; WIDTH: 568pt; BORDER-BOTTOM: #d4d0c8; HEIGHT: 12.75pt; BACKGROUND-COLOR: transparent" width=757 height=17>http://www.dieselmanor.com/diy/PSD3-gauge/PSD60gauge-p1.htm</TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD class=xl24 style="BORDER-RIGHT: #d4d0c8; BORDER-TOP: #d4d0c8; BORDER-LEFT: #d4d0c8; WIDTH: 568pt; BORDER-BOTTOM: #d4d0c8; HEIGHT: 12.75pt; BACKGROUND-COLOR: transparent" width=757 height=17>http://www.itpdiesel.com/other/6.0L%20Gauge%20Kit%20Instructions.pdf</TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD class=xl25 style="BORDER-RIGHT: #d4d0c8; BORDER-TOP: #d4d0c8; BORDER-LEFT: #d4d0c8; WIDTH: 568pt; BORDER-BOTTOM: #d4d0c8; HEIGHT: 12.75pt; BACKGROUND-COLOR: transparent" width=757 height=17>Removing the exhaust manifold</TD></TR></TBODY></TABLE>
https://www.ford-trucks.com/forums/6...ight=egt+probe
Old Aug 11, 2008 | 06:34 AM
bismic's Avatar
bismic
OIL TEMPERATURE and PRESSURE:
<TABLE style="WIDTH: 568pt; BORDER-COLLAPSE: collapse" cellSpacing=0 cellPadding=0 width=757 border=0 x:str><COLGROUP><COL style="WIDTH: 568pt; mso-width-source: userset; mso-width-alt: 27684" width=757><TBODY><TR style="HEIGHT: 12.75pt" height=17><TD class=xl24 style="BORDER-RIGHT: #d4d0c8; BORDER-TOP: #d4d0c8; BORDER-LEFT: #d4d0c8; WIDTH: 568pt; BORDER-BOTTOM: #d4d0c8; HEIGHT: 12.75pt; BACKGROUND-COLOR: transparent" width=757 height=17>Oil pressure, get a billet oil filter cap or use the test port.</TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD class=xl24 style="BORDER-RIGHT: #d4d0c8; BORDER-TOP: #d4d0c8; BORDER-LEFT: #d4d0c8; WIDTH: 568pt; BORDER-BOTTOM: #d4d0c8; HEIGHT: 12.75pt; BACKGROUND-COLOR: transparent" width=757 height=17></TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD class=xl24 style="BORDER-RIGHT: #d4d0c8; BORDER-TOP: #d4d0c8; BORDER-LEFT: #d4d0c8; WIDTH: 568pt; BORDER-BOTTOM: #d4d0c8; HEIGHT: 12.75pt; BACKGROUND-COLOR: transparent" width=757 height=17>Oil temp - get a billet aluminum filter cap or use the test plug on the filter housing.</TD></TR></TBODY></TABLE>
Old Aug 11, 2008 | 06:35 AM
bismic's Avatar
bismic
COOLANT TEMPERATURE:
<TABLE style="WIDTH: 568pt; BORDER-COLLAPSE: collapse" cellSpacing=0 cellPadding=0 width=757 border=0 x:str><COLGROUP><COL style="WIDTH: 568pt; mso-width-source: userset; mso-width-alt: 27684" width=757><TBODY><TR style="HEIGHT: 38.25pt" height=51><TD class=xl25 style="BORDER-RIGHT: #d4d0c8; BORDER-TOP: #d4d0c8; BORDER-LEFT: #d4d0c8; WIDTH: 568pt; BORDER-BOTTOM: #d4d0c8; HEIGHT: 38.25pt; BACKGROUND-COLOR: transparent" width=757 height=51>For coolant temp, look on the block at the back on the driver side. There is a plug that you can remove and install an adapter (Autometer PN 2268 IIRC) which will adapt the 16X1.5mm (male) plug hole to 1/8 NPT (female) for the temp probe ($6.45 at Diesel Manor link below).</TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD class=xl24 style="BORDER-RIGHT: #d4d0c8; BORDER-TOP: #d4d0c8; BORDER-LEFT: #d4d0c8; WIDTH: 568pt; BORDER-BOTTOM: #d4d0c8; HEIGHT: 12.75pt; BACKGROUND-COLOR: transparent" width=757 height=17>http://www.dieselmanor.com/diy/Ford_water60.htm</TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD class=xl24 style="BORDER-RIGHT: #d4d0c8; BORDER-TOP: #d4d0c8; BORDER-LEFT: #d4d0c8; WIDTH: 568pt; BORDER-BOTTOM: #d4d0c8; HEIGHT: 12.75pt; BACKGROUND-COLOR: transparent" width=757 height=17>https://www.ford-trucks.com/forums/761816-water-and-oil-temp-gauge-sender-location.html</TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD class=xl25 style="BORDER-RIGHT: #d4d0c8; BORDER-TOP: #d4d0c8; BORDER-LEFT: #d4d0c8; WIDTH: 568pt; BORDER-BOTTOM: #d4d0c8; HEIGHT: 12.75pt; BACKGROUND-COLOR: transparent" width=757 height=17>Or you can put the probe in a port on the bypass filter.</TD></TR></TBODY></TABLE>
Old Aug 11, 2008 | 09:27 PM
Green_Monster
Bis
Thanks for all of that info I believe that will answer my Questions. On the egt pre and post teh way you wrote it it seems like they are going both in the drivers side exhaust manifold? Which I know cannot be right. That was one of my questionsThe psot turbo egt probe I have seen goes in the down pipe(?) as a banded thermocoupler with probe.
Also I read that a probe in the transmission test port is not an accurate reading is that true?
Going to research all of those links..............................
Bismic BIG THUMBS UP
Old Aug 12, 2008 | 12:02 AM
Benchwrench's Avatar
Benchwrench
One of the gauges I left out of my install was the oil gauge.
I ended up with 5 autometer gauges.
Boost
EGT
Trans Temp.
H2O Temp.
Fuel Press.
I think if a guy was to install an oil gauge the oil filter cap would be the best, however this is a coveted application as an oil bypass filter will utilize this placement as would both oil pressure and oil temp gauges. Then there routine oil filter changes where having a line on the cap would become a hassle.
It seems an oil port somwhere else would be a great asset to tap.
Mark, you're such a posting guru. Thanks for all the gauge related info.
(Rep points given)
Old Aug 12, 2008 | 08:43 AM
scameron's Avatar
scameron
benchwrench where did you put all your gauges?
Old Aug 12, 2008 | 09:20 AM
jmaskew's Avatar
jmaskew
(Rep points given)
I have the aluminum billet oil filter cap from EliteDiesel.com and oil temp sender. It is no problem at all to take off the oil filter cap. There is a connector about 5 inches from the temp sender that you unplug before removing the billet cap.... no hassle at all. Maybe in the future they will make an oil filter cap with 3 ports on it for temp, pressure and bypass!! I don't think you would get accurate readings with a "T" fitting.
Old Aug 12, 2008 | 11:30 AM
Benchwrench
One other concern regarding the oil filter cap is my need to put a torque wrench on it once a new filter is replaced which means fitting a socket on the cap. With an oil line on the top, R&R is the only option unless someone finds a place to "tap" in the oil system where doing an R&R to the line and fittings won't be necessary each filter service.
Below are my dash install pics. I like the dash placement better than the pillar as I would have lost the grab bar and the one over the mirror brought the mirror down too far and it also obstructs the lower half of each dial.
The 5 gauges are set just a bit brighter than the factory dash lights so when my eyes adjust to long haul night runs,
I can turn down the cluster way low and the five gauges are lit just brighter than the OEM dash cluster.
This is those times when you're 'bout spent and oncoming light are a bother.
Old Aug 12, 2008 | 12:19 PM
jmaskew's Avatar
jmaskew
Nice pictures!!! You can't beat a King Ranch interior! I didn't realize you used a torque wrench on the filter cap so that would make perfect sense where the sensor would get in the way.
My boost gauge is a little brighter than the other gauges so I took a "sharpie permanent marker" and put a couple of stripes on the bulb which worked very well. Now it's about the same brightness as the other gauges.
Old Aug 12, 2008 | 02:49 PM
Benchwrench
Thanks.
You can also use a half watt 1.2k ohm resistor for your bright gauges to dim them down closer to the brightness of the dash cluster.
(The 1.2k ohm is just a reference point to begin adjustment, you may need to go with a 980 or 1.4k ohm)
For those gauges that have an incandescent lamp instead of L.E.D.'s can benefit with the use of those little colored condoms that slide over the lamp to change the color of the dial.
