Guages installed.
Old Aug 9, 2008 | 01:38 PM
1nascar24fan's Avatar
1nascar24fan
Guages installed.
I finished with my guage install a while back ,everything works fine except the lighting. When its dark and the lights are on the top light is brighter than the next one down and that one is a little brighter than the next one ,,I hooked it up as specified so any help would be appreciated, thanks for the great site!!
Old Aug 9, 2008 | 08:09 PM
zx250's Avatar
zx250
Of the next Riffraff East
Well, the top one is closer to you.........Don't know what it could be. I have the Autometers as well and if anything, the top may be just a tiny little bit dimmer than the bottom one. Other that switching bulbs around and checking splices and connections, just don't know what to tell you.
Old Aug 9, 2008 | 10:34 PM
camodown's Avatar
camodown
Did you daisy chain them together? The current loss in the wire is infintessimally small, but I have had wire with impure copper before oddly enough. Is the wire good? Is it possible one terminal has a bad connection? I presume these are the bulb type, not LED type? My only suggestion is to isolate each gauge and if they are still lighting up funny, check bulbs and for corrosion on connections...
Old Aug 9, 2008 | 10:36 PM
camodown's Avatar
camodown
What kind of connectors were used? The cheap ones don't conduct electricity well, and tend to create a bit more resistance than they should. Of course if you wired in parallel the connectors wouldn't make any difference, but I am thinking you wired in series
Redonkulous BOB
Dec 22, 2011 12:44 PM
LawF250
1978 - 1996 Big Bronco
Sep 2, 2011 01:28 AM
jaye
Jan 21, 2011 04:33 PM
EPNCSU2006
Electrical Systems/Wiring
Oct 26, 2006 02:40 PM
rufaast
May 4, 2006 10:35 AM
