Trany Coolers
Old Aug 9, 2008 | 09:18 AM
JRCF's Avatar
JRCF
Trany Coolers
1995 Ford F150 just put in a 6'' lift kit and 35's on er. Wanting to upgrade the trany cooler whats my best bang for the buck???
Old Aug 9, 2008 | 10:19 AM
gweeds's Avatar
gweeds
I just installed a darale cooler with an electronic fan and temperature relay. It looks to be the biggest cooler that will fit behind the grille, and I did do a minor amount of trimming to get of in there. And I had to make some custom brackets to mount it. I havent takenit off road yet, so I don't know yet how well the fan works, but it hasn't even hit the threshold (160-is degrees F) at which the fan turns.
That said, if you are planning ok doing any off-roading that involves low speeds, a fan cooler may be a good investment. Otherwise it's a bit frivolous.
Old Aug 9, 2008 | 10:42 AM
quicklook2's Avatar
quicklook2
gweeds, i heard that was an excellent cooler.
friend's with muscle cars in southern california that i know swear by these.
Old Aug 9, 2008 | 10:50 AM
JRCF's Avatar
JRCF
Sounds like a great idea, My only concern would be Serious mud getting into the fan motor and blade, should this be a concern?
Old Aug 9, 2008 | 10:53 AM
gweeds's Avatar
gweeds
yeah you can tell that it's just a very high quality product. Things not made in china are getting more and more difficult to come by. I'll post some pictures of the install when I get the chance.
Old Aug 9, 2008 | 10:56 AM
gweeds's Avatar
gweeds
you might want to cover it in some sort of removable fine mesh or something like that.
Old Aug 9, 2008 | 11:21 AM
JRCF's Avatar
JRCF
Hmmm, teah that would be an opytion, I have posession 2 trany coolers from F150's I was thinking about mounting the second one and running them together. I mean I have them there wont cost me a dime. but will it be effective enough??
Old Aug 9, 2008 | 11:28 AM
quicklook2's Avatar
quicklook2
any extra cooling helps.
enough?
the temp gauge is the only way to know.
Old Aug 9, 2008 | 11:29 AM
gweeds's Avatar
gweeds
well it would cost you a few bucks for the hose. The only way to know if it's effective is to install a temperature gauge in the transmission and monitor the temp. or, is somebody else on this forum reccomended to me, use an infrared thermometer on the pan to check the temp.
Old Aug 9, 2008 | 11:59 AM
JRCF's Avatar
JRCF
These trucks dont come factory with a trany temp gauge, so how do you go about putting a mechanical one in? pan in line? What is the recommended operating temperature?
Thanks!
C-700
Apr 29, 2014 10:30 AM
jav409
21
Oct 31, 2005 04:05 PM
wycowboy
All Things Towing
Apr 24, 2005 10:16 PM
wycowboy
Apr 12, 2005 02:17 PM
Rat A Tat
Jun 10, 2003 04:54 PM
