Rear Gear Advice
if you dont have experience installing ring gears and dont want to pay someone else to do it, youre best bet would be to find a parts truck and just swap the entire rear/front ends out.
Does anyone know the code on the Mfr Sticker on the door jamb to tell what gears I have?
here is an axle code chart.
Code Ratio Capacity Maker Type Yr
12 2.73 3800 FORD REG 1991
17 3.25 3300 FORD REG 1971
17 3.31 3800 FORD REG 1995
18 3.08 3800 FORD REG 1991
19 3.55 3800 FORD REG 1991
25 4.10. 5300 FORD REG 1991
29 3.55 5300 FORD REG 1991
35 4.10. 6250 FORD REG 1991
36 3.73 7400 DANA REG 1980
39 3.55 6250 FORD REG 1991
45 4.10. 7400 FORD REG 1991
49 3.55 7400 FORD REG 1991
65 4.10. 8250 FORD REG 1991
69 3.55 8250 FORD REG 1991
72 4.63 11000 DANA REG 1991
73 5.13 11000 DANA REG 1991
H5 4.10. 3800 FORD LIMITED SLIP 1991
H7 3.31 3800 FORD LIMITED SLIP 1995
H8 3.08 3800 FORD LIMITED SLIP 1991
H9 3.55 3800 FORD LIMITED SLIP 1991
B5 4.10. 5300 FORD LIMITED SLIP 1991
B9 3.55 5300 FORD LIMITED SLIP 1991
C5 4.10. 6250 FORD LIMITED SLIP 1991
C9 3.55 6250 FORD LIMITED SLIP 1987
D5 4.10. 7400 FORD LIMITED SLIP 1991
F5 4.10. 8250 FORD LIMITED SLIP 1991
W5 4.10 8250 FORD LIMITED SLIP 1995
a 265/75 means my tire is 265 mm wide. 265 mm wide x 75%=198.75 mm tall sidewall. so really, my tire is 1 mm shorter than yours. which would make me turn about 1 rpm more than you at 60 lol. either way, its the same as a stock tire when it comes to speedo/tach numbers.
your axle code will only tell you what gear it came with stock. your code may say 4.10, but that doesnt mean thats whats it has. but bottom line, if youre running the correct size tire and turning 2300 rpm at 60 mph, you dont have 4.10's. so no, your tire size isnt trivial. especially if youve got the wrong size.
A half dozen or less tows a year at ~60mph, or spent $500+ to upgrade gears for marginal savings - six in one half dozen the other I recon
and it seems to me that a motor that is turning 2700 rpms over 200,000 miles would have far less life left than a motor that has been running 2200 for the same number of miles.
