Sponsored by: Real Truck
Do axles bend in roll-overs?
Old Aug 8, 2008 | 02:03 PM
mizzitch's Avatar
mizzitch
I am looking to swap in a Dana 60 in my 1999 F-250. The yard has an axle on a 2004 that fits my needs, but the truck was rolled.
So should the axle be fine, if the roll-over was not too severe?
Old Aug 8, 2008 | 02:13 PM
redford's Avatar
redford
FTE Leadership Emeritus
Any part taken from a vehicle that was rolled should be checked before being reused. Chances are it's OK, but you never know what the truck was subjected to in the way of G forces. Axles can be snapped, axle housings can be cracked or twisted, frames can be twisted, engine blocks cracked, basically darn near anything can break.
Old Aug 8, 2008 | 02:51 PM
ReAX's Avatar
ReAX
Sounds like a good excuse to get one of those laser levels. Shoot the beam at three axis and measure it up.
Old Aug 8, 2008 | 04:36 PM
yukondiesel's Avatar
yukondiesel
Keep looking...I wouldn't touch it
Old Aug 8, 2008 | 04:41 PM
RDJ184's Avatar
RDJ184
they can be bent most of the time they are!!
Old Aug 8, 2008 | 04:50 PM
05lariatPSD's Avatar
05lariatPSD
The way I see it. When the truck rolled, it probably put a lot of stress on the wheels. If it rolled more than once, it would have come down on the wheels pretty hard when it was right side up.
In addition, if it landed on it's roof, I'm sure a lot of stress was put on the wheels when the righted it.
I would try to find another axle if you have any doubts at all.
Old Aug 8, 2008 | 04:52 PM
Green Ford's Avatar
Green Ford
I have to agree it's just not worth the risk.
Old Aug 8, 2008 | 06:44 PM
XLnAK's Avatar
XLnAK
You should pick it up, If a song is all they want? A buddy rolled his way new mopar, and its back and front differentials lived. But if one of them hadn't , the rig was just a few grand from total status. Get a written agreement of return for any defect, if they are asking for a album or two. Be sure to check everything. Plug up all openings and slightly pressurize the unit to check for cracks maybe, at least the yard admits the thing is out of a rollover. Some would take it out and seller on E-bay. good hunting.
Old Aug 8, 2008 | 06:48 PM
2002 F350V10's Avatar
2002 F350V10
I would just check it and go from there. it should be obvious if it is bent.
Old Aug 8, 2008 | 07:25 PM
mizzitch's Avatar
mizzitch
I think I may go take a look at the axle and truck, if they are open on tomorrow...
Thanks for the advise.
Old Aug 8, 2008 | 09:55 PM
aldridgec's Avatar
aldridgec
It's a little tougher to check a bend front axle. But, it is likely that any part on any vehicle that is in a wreck can be affected. Just take the great advice everyone offered into consideration. I can't add anything!
Old Aug 8, 2008 | 10:00 PM
1's Avatar
I recommend to keep searching. Seen too many trucks get flipped back over after a roll, and that alone is really hard on teh axles. Let alopne the trucks flyinga nd rollingw ith speed!!!
woodtrucker
Oct 4, 2013 11:09 AM
the Mad Modder
1983 - 2012 Ranger & B-Series
Jul 12, 2008 05:49 AM
Dereck
Sep 21, 2007 07:51 PM
jgc2521
1978 - 1996 Big Bronco
17
Oct 14, 2005 02:22 PM
54Guy
Bronco II
18
Aug 31, 2005 02:01 PM
