Click and dead
Old Aug 7, 2008 | 09:05 PM
65_4_Fun's Avatar
65_4_Fun
Click and dead
Stopped by the store on the way home in my 94 F150 I6 tonight. Truck was running fine, when I came back out about 10 min later and tried to start the truck I hear a loud click and then it is dead. No power to anything except the small light under the hood.
Tried to jump start it but still dead, no power to anything even no headlights.
Any ideas on what is wrong?
Thanks
Marty
Old Aug 7, 2008 | 10:49 PM
lv2race's Avatar
lv2race
Try removing your battery cables and cleaning the posts and clamps for a good connection. Possible starter solenoid on the fender wall or fusible link at the starter solenoid.
Old Aug 8, 2008 | 12:47 AM
quicklook2's Avatar
quicklook2
spade connector on starter.
pull it off put it back on.
bet it starts.
later, take it of again and clean the connection and crimp connector a little.
Old Aug 9, 2008 | 10:08 AM
lostin90s's Avatar
lostin90s
Also check connections on fender(seloniod ) the S wire will work loose.
Old Aug 9, 2008 | 10:53 AM
fbama73's Avatar
fbama73
Ditto what Quicklook said. When I saw the title of the thread, that's the first thing I thought, even before reading the specifics.
Those spade connectors are the devil.
Old Aug 9, 2008 | 07:19 PM
85e150's Avatar
85e150
Check the connections regardless....but, is there any juice at all? This sounds like 'sudden battery death'. Had this happen about 3 or 4 times--the battery melts inside & you can't even jump the car after that.
Anyways, check as per prior posts no matter what, but first see if there is anything left in the battery.
Old Aug 9, 2008 | 07:48 PM
danr1's Avatar
danr1
The guy that came up with that little spade connector down on the starter needs five across the lips.
Old Aug 9, 2008 | 09:00 PM
fbama73's Avatar
fbama73
^ Way too nice, way too simple. Let ME have the guy. I can be very creative.
Old Aug 9, 2008 | 09:51 PM
danr1's Avatar
danr1
That was the "forum friendly" version.
But yea if you get a hold of em, do as you will
Old Aug 9, 2008 | 10:05 PM
tjthegreat's Avatar
tjthegreat
someone please explain 2 me about spade connectors
Old Aug 9, 2008 | 10:16 PM
quicklook2's Avatar
quicklook2
it is a male connector slipped into a female connector.
it corrodes.
Old Aug 9, 2008 | 10:18 PM
tjthegreat's Avatar
tjthegreat
...o thanks
Old Aug 10, 2008 | 08:11 AM
subford's Avatar
subford
It is a female connector slipped onto the male connector of the Starter.
Spade Connectors - female
Old Aug 10, 2008 | 08:36 AM
subford's Avatar
subford
Thanks
Marty
However this does not sound like the spade connector.
If you do not have any power to the dash/headlights and the battery is OK then we need to look at something else.
Get a test light and check for power at Fuse "P" in your under hood fuse box, this is a 50 Amp fuse. If Fuse "P" is OK on both sides then you may have a bad Ignition Switch or the plug that plugs into it.
If fuse "P" is dead on both sides then there may be a bad connection where the fuse links A & B in the above diagram are bolted onto the starter relay or A & B fuse links may be open. If they are open then you may have a short to ground between the fuse links A & B and the fuse box under the hood at fuse "P".
Old Aug 11, 2008 | 12:22 AM
Creel's Avatar
Creel
Ditto, I've had the spade connecter go bad on me, and it didn't affect lights, etc. Only the starter. I'd go with lv2race's first sentance as the first step, then subfords if the first doesn't fix it.
Marty in PA
Aug 2, 2024 10:09 AM
1amante
Feb 26, 2014 06:27 AM
Marty Smilt
Feb 23, 2013 07:32 PM
Marty86
23
Jan 26, 2007 11:20 PM
jonny_blue
Electrical Systems/Wiring
Sep 26, 2005 08:56 PM
