ok, I recently installed the new PDR turbo, works great, lately my egts have been up more than usual, I have leaky up pipes for sure, but there is also soot on the ex housing the middle cartridge and back side of compressor housing...as well as alllllll over my pedistal, now is this from the up pipes of could something else be loose? also my wastegate rod has oil on it?
sounds to me like you didnt line up the pin on the babies butt to the back of the turbo when you installed it... on a cold motor..start it up..reach behind the turbo and feel around the clamp that holds the up pipes to the turbo...im sure you will find it leaking..
no leak on baby's butt, most definatley up pipes, could feel it with ease....now ceramic coated or just normal bellowed up pipes? how big of an advantage is the coating?
