fuel gauge
Old Jun 23, 2002 | 08:58 PM
fiend's Avatar
fiend
fuel gauge
I posted this in this 87-96 forum but thought i'd get a better response here.
I filled my tanks up tuesday, and they are still pretty much at full as of sunday, and I usually go through a half a tank a week.
I'm thinking something is wrong with the gauge/wires. I did some searching in this forum, and it says I need to test the wires by grounding them and if the gauge goes to full it's bad. But I can't find out where the wires are in my Haynes manual. Any help?
I couldn't find anything on how to check the gauge its self, can anyone help me with that?
Thanks.
Old Jun 23, 2002 | 09:40 PM
Mil1ion's Avatar
Mil1ion
fuel gauge
[updated:LAST EDITED ON 23-Jun-02 AT 10:42 PM (EST)]They are on the sending units > at the Fuel Tanks.
I've posted the instructions for this test at 20 times.
Maybe have a look through the other posts as they all work the same way.
Look for "gauges don't work" or something like that *in the search function*.
[font color=red]Dennis
Calgary,Alberta,Canada[/font]
[link:www.ford-trucks.com/guidelines.html|FTE Moderator]
http://www.clubfte.com/users/mil1ion/Minimorleytruck.JPG
[link:www.clubfte.com/users/mil1ion/Mil1ion.html|My Website,"North Of The 49th"]
[font color=red]
Please Don't Ask Me Any Tough Questions,
"I'm Saving My Memory For When I Develop Alzheimer's" [/font]
[font color=blue]78 F-150 429CJ,Silver,Explorer Pkg.
[/font]
Old Jun 23, 2002 | 10:02 PM
fiend's Avatar
fiend
fuel gauge
I've searched, and I have the instructions on how to check them.
What I can't find is where exactly the wires are, i'm a newb so saying that they are in the sending units doesn't help so much. What is a "cotter pin"?
Thanks, I appreciate it.
Old Jun 23, 2002 | 10:12 PM
Mil1ion's Avatar
Mil1ion
fuel gauge
[updated:LAST EDITED ON 23-Jun-02 AT 11:13 PM (EST)][link:www.ford-trucks.com/dcforum/80_96/7112.html|Gauge Testing procedure]
A cotter pin is the pin that holds hub on a wheel.
It goes through a castle nut to hold everything together on adjusting front wheel bearings.
I suggest these because they expand plus they hold inwards or outwards.
The sending units are usually on top of the fuel tank.
The other way is to pull the instrument cluster but by-passes a possible wiring problem.
[font color=red]
[/font]
Old Jun 23, 2002 | 10:28 PM
fiend's Avatar
fiend
fuel gauge
Do I have to drop the tank to check the sending units? Or are they easy to get to without taking anything tank related apart?
Old Jun 24, 2002 | 12:23 PM
Mil1ion's Avatar
Mil1ion
fuel gauge
The front tank should be the easiest & you only have to do one to verify whether it's the gauge or wiring.
Doing Both though:
This also gives you a chance to clean off the contacts which in itself
may fix your problem.Connections under the truck have a tendency to corrode.
http://www.clubfte.com/users/mil1ion/canada_flag_animated.gif
[font color=red]
[/font]
Old Jun 25, 2002 | 07:12 AM
fiend's Avatar
fiend
fuel gauge
Thanks for everything but I was amazed yesterday when I went and filled up my tank. I had went that week on my first, and the second two days on my 2nd tank. And it only took 5 gallons to fill them both up!
So I must have been getting some sweet gas mileage or something! Thanks for the help though.
Old Jun 25, 2002 | 10:37 PM
Mil1ion's Avatar
Mil1ion
fuel gauge
FORDF250HDXLT
May 11, 2016 07:54 AM
AKHunter93
Aug 14, 2015 10:56 PM
DR Smith
24
Jun 13, 2014 03:36 PM
racine
Apr 29, 2013 05:05 PM
CClark56
Oct 11, 2010 11:55 AM
