i got a 1989 f-150 4x4 with the 300 inline 6 i just put in a brand new gas tank and fuel pump and now my fuel gauge not working right
Can you give a little more information?
What fuel pump is not working, the one on the frame or in one of the tanks?
Do you have two tanks?
If you have two tanks does the other tank work OK?
There are two separate devices in the tank. The pump, and the float. If you bent the arm of the float, or cracked the float, it will be stuck in one postion or if the float is cracked and filled with gas , then it will always read empty.
The float assy. sits close to the sidewalls of the midships (front) tank, and it may be jammed up against the inside of the tank wall. come on back bmacky 14
