385 Series Heads
Old Aug 6, 2008 | 06:13 PM
Rebel Warrior's Avatar
Rebel Warrior
Smile 385 Series Heads
I was cleaning the garage up and decided it was time to unload a set of cylinder heads I was saving for my project. but with Gas the way it is. I know they're from the 60's but off of what? maybe you guys can shed some light. the casting # is C9VE-A This is the number by the valve cover lower rail & above the exhaust ports.
Old Aug 6, 2008 | 06:47 PM
tankrsc's Avatar
tankrsc
Its from a '69 but just from the casting number could be from anything that had a 429/460. That is a desired head though the C's are very good
Old Aug 6, 2008 | 07:18 PM
Rebel Warrior
Thanks for the info. I'm kinda hoping Numbers Dummy will resond. He should know!
Old Aug 7, 2008 | 01:41 PM
hairyboxnoogle's Avatar
hairyboxnoogle
Where are you at? I wouldnt mind a set of good heads.
Old Aug 7, 2008 | 01:42 PM
fmc400's Avatar
fmc400
MSEE
Alternatively you might try the 385-series forums because they go into a lot of detail on those engines in that forum.
