Sponsored by: Innova
Installation Brackets
Old Aug 6, 2008 | 04:24 PM
jpr38057's Avatar
jpr38057
I am going to be installing a JVC double din head unit in both my 2004 ex and my wifes 2005 ex. What in the way of aftermarket brackets am I going to need? Any suggestions on sources and part #'s?
Old Aug 6, 2008 | 04:29 PM
ReAX's Avatar
ReAX
I don't think there is going to be an install kit available. However, I think it will be pretty easy to mod the dash to make it work. you might have to cut some plastic, trim the stock slider bar, and square up the opening.
Once you have the opening big enough, you can mount the cage and slide it in.
Old Aug 6, 2008 | 04:31 PM
ReAX's Avatar
ReAX
On the electrical side, Metra will have the harnesses you need to make it plug-n-play.
Are you doing Sat radio or nav?
Old Aug 6, 2008 | 05:03 PM
Beerstalker's Avatar
Beerstalker
Use the 99-5805 install kit for an explorer. It is what I used in my 99 F250. It takes a little bit of modifying, but you should be able to figure it out.
99-5805 Radio mounting dash kit;
I would recommend using the Schosche wiring adapter instead of the Metra. It has a couple extra wires that you might want for your install like the steering wheel control wire and VSS wire.
Old Aug 6, 2008 | 05:47 PM
jpr38057's Avatar
jpr38057
No sat or nav
Beerstalker,
I already have the Scosche harnesses because I had seen one of your previous posts. I have the dremel ready to take care of the upper and lower lips. With that kit is there more modification necessary? No big deal if there is.
Thanks guys
USMC616
May 31, 2015 12:58 PM
Pa&Nic51
Jun 17, 2011 02:39 PM
97_Ex
May 17, 2007 07:29 PM
BFTExcursionV10
Apr 13, 2006 11:25 PM
