Rear differential?
Old Aug 6, 2008 | 12:20 PM
DemonRace6's Avatar
DemonRace6
Hi!
Rear differential?
I replaced my front brakes last night, went well for my first time doing brakes too.
While I was under the truck though I noticed my rear differential cover had a slight crack in it and was leaking slow.
So I am looking for a new one but I don’t know what type of rear diff I have, Dana…
How can I tell what type of diff I have? And what fluid does it take, also what fluid does the front diff take? Thanks!
Old Aug 6, 2008 | 12:56 PM
rugermack's Avatar
rugermack
Your rear is a 10.25 sterling, the front on an 01' is a dana 50. You can get a rear cover from diesel Manor for about $60 bucks. The rear takes synthetic oil 140w, like this one:
Old Aug 6, 2008 | 12:57 PM
TxFordGuy's Avatar
TxFordGuy
Buy one like this then. I got one from the FORD house with discount for $45. bolts right up
Ford 12 Bolt 10.25 & 12 Bolt 10.5 OEM Aluminum Differential Cover
Old Aug 6, 2008 | 01:24 PM
rugermack's Avatar
rugermack
That's the same one in the picture, you can buy it for $60 something with the bolts and washers. It is a Ford rear cover, it comes off an 08'.
Old Aug 6, 2008 | 01:30 PM
brian42's Avatar
brian42
Veteran: Navy
I second the Diesel Manor cover. I bought mine for $67 and some change and it was the '08 aluminum cover (comes with bolts too).
You want 75W140 gear oil for the rear. If you have an LS you can either buy the friction modifier from Ford (4 oz bottle) or get gear oil with it in it (like Mobil 1).
Old Aug 6, 2008 | 02:05 PM
DemonRace6's Avatar
DemonRace6
Hi!
How did you get a discount? That site sells it for $79. Thanks
Old Aug 6, 2008 | 02:12 PM
deereman4020's Avatar
deereman4020
actually the rear axle on the 99-07 series F-series has the sterling 10.5 inch rear end if that makes a difference at all
Old Aug 6, 2008 | 02:37 PM
rugermack's Avatar
rugermack
Same cover, only difference is the size of the ring gear.
Old Aug 6, 2008 | 03:04 PM
camodown's Avatar
camodown
If the truck is a SRW it is a 10.5" ring gear, DRW is a Dana 80. I have a stock cover that was on my bad differential if you want it. Just pay shipping... I am otherwise going to trash the axle
Old Aug 6, 2008 | 03:05 PM
Ponyboychris's Avatar
Ponyboychris
Not to split hairs but use only Syn. 75W140...
Old Aug 6, 2008 | 03:51 PM
DemonRace6's Avatar
DemonRace6
Hi!
As long as it is in good condition yes please! PM sent. Thanks!
Old Aug 6, 2008 | 08:31 PM
TxFordGuy's Avatar
TxFordGuy
demonrace, i posted that link b/c i was just trying to show him which one to get. i forgot dieselmanor sold it too. i got a discount b/c i have a buddy who is a mechanic is gets shop pricing from FORD.
Old Aug 6, 2008 | 09:29 PM
Ponyboychris
Just remember, if you go with the '08 style cover, you need longer bolts. The ones for the stamped steel cover are not long enough.
Old Aug 7, 2008 | 11:49 AM
DemonRace6's Avatar
DemonRace6
Hi!
I just ordered a new one. Thanks everyone!
Old Aug 19, 2008 | 11:32 PM
DemonRace6's Avatar
DemonRace6
Hi!
Just finished replacing my diff cover, not sure how to post pics yet so here is the link to my the pictures I took: 08.08.19 Rear Dif Cover - a set on Flickr
