Rear differential?
I replaced my front brakes last night, went well for my first time doing brakes too. :-jammin
While I was under the truck though I noticed my rear differential cover had a slight crack in it and was leaking slow. :-banghead So I am looking for a new one but I don’t know what type of rear diff I have, Dana… How can I tell what type of diff I have? And what fluid does it take, also what fluid does the front diff take? Thanks! |
Your rear is a 10.25 sterling, the front on an 01' is a dana 50. You can get a rear cover from diesel Manor for about $60 bucks. The rear takes synthetic oil 140w, like this one:
http://webpages.charter.net/fivonut/cover%20002.jpg |
Buy one like this then. I got one from the FORD house with discount for $45. bolts right up
Ford 12 Bolt 10.25 & 12 Bolt 10.5 OEM Aluminum Differential Cover |
Originally Posted by TxFordGuy
(Post 6423025)
Originally Posted by rugermack
(Post 6423023)
You want 75W140 gear oil for the rear. If you have an LS you can either buy the friction modifier from Ford (4 oz bottle) or get gear oil with it in it (like Mobil 1). |
(Post 6423025)
actually the rear axle on the 99-07 series F-series has the sterling 10.5 inch rear end if that makes a difference at all
Same cover, only difference is the size of the ring gear.
If the truck is a SRW it is a 10.5" ring gear, DRW is a Dana 80. I have a stock cover that was on my bad differential if you want it. Just pay shipping... I am otherwise going to trash the axle
Originally Posted by brian42
(Post 6423142)
Originally Posted by camodown
(Post 6423424)
demonrace, i posted that link b/c i was just trying to show him which one to get. i forgot dieselmanor sold it too. i got a discount b/c i have a buddy who is a mechanic is gets shop pricing from FORD.
Just remember, if you go with the '08 style cover, you need longer bolts. The ones for the stamped steel cover are not long enough.
I just ordered a new one. Thanks everyone!
Just finished replacing my diff cover, not sure how to post pics yet so here is the link to my the pictures I took: 08.08.19 Rear Dif Cover - a set on Flickr
