7.3 6.9 injection pumps Question
Old Aug 6, 2008 | 09:28 AM
rodymartin's Avatar
rodymartin
Question 7.3 6.9 injection pumps Question
I am swaping a 6.9 for the blown 7.3 I have. Can I use the 7.3 injection pump?
Old Aug 6, 2008 | 10:25 PM
Dave Sponaugle's Avatar
Dave Sponaugle
All the IDI injection pumps will work on any IDI engine.
Fuel delivery quanity is close on all of them.
Pop pressures changed a little, so it would be best if you use the correct injectors for the IP you run.
The only two IP's that are much different are the DB2-5069 and DB2-5070 that was used on the 93 and 94 IDI turbo engines with G injectors.
Fuel delivery is higher, and the timing curve is slightly different to take advantage of the turbo.
Yes, if you want to you can bolt a 7.3 turbo IP and turbo injectors right on a 1984 6.9.
But the result will be lower MPG and more black smoke since it is not getting the extra air from the turbo.
72f2504x4390
19
Mar 23, 2018 02:09 AM
trevorrules
19
Apr 11, 2015 12:05 AM
bill11012
Jun 2, 2010 01:31 AM
hooksetz
Aug 11, 2008 10:19 PM
vaman4215
Jul 23, 2007 10:32 PM
