Fresh frame and rear suspension?
Old 08-06-2008, 07:58 AM
JBravo's Avatar
JBravo
JBravo is offline
Ok... I got a fresh '55 frame for my '56 yesterday... Spent more in diesel fuel than the actual frame but thats for another forum...
I'm 95% sure I want to put a 4-link in the rear for strength and ride quality. I'm planning on running a 460 and abusing it when the need arises...
Am I heading the right direction? What company would you go with for the 4-link?
Thanks,
JB
Old 08-06-2008, 07:59 AM
JBravo's Avatar
JBravo
JBravo is offline
Forgot to add I'm also planning on running some sort of air bags front and back as well...
JB
Old 08-06-2008, 10:12 AM
sdetweil's Avatar
sdetweil
sdetweil is offline
TCI does all that.. and supports airbags
Sam
Old 08-06-2008, 11:08 AM
JBravo's Avatar
JBravo
JBravo is offline
Sam,
Is that the setup in your ride?
Old 08-06-2008, 11:14 AM
sdetweil's Avatar
sdetweil
sdetweil is offline
On the 54 in my gallery, yes... the green 55 uses a volare front and mustang 8.8 rear.
on the 54 we used the TCI Mustang II front end, and the TCI leaf spring kit, not the 4 bar.
Sam
Old 08-06-2008, 01:37 PM
JBravo's Avatar
JBravo
JBravo is offline
After comparing prices... maybe a leaf spring setup in the back will suffice...
JB
Old 08-06-2008, 01:43 PM
sdetweil's Avatar
sdetweil
sdetweil is offline
yeh, all the 'cool' solutions are not cheap..!
Sam
Old 08-06-2008, 01:45 PM
JBravo's Avatar
JBravo
JBravo is offline
If money wasn't so expensive I would get some more... then I COULD have the cool stuff...
Old 08-06-2008, 02:49 PM
CharlieLed's Avatar
CharlieLed
CharlieLed is offline
Jason Thorbecke at Suicidedoors.com will hook you up. I designed a 4-link triangulated suspension for my 56 and he built it to spec. I can send you the drawings if you wish. The beauty of a triangulated setup is that there is no panhard bar. Thorbecke also has a full line of airbag bracketry and equipment.
Old 08-06-2008, 02:55 PM
sdetweil's Avatar
sdetweil
sdetweil is offline
My tubs were from Jason. I am running a triangulated system for the ford 8.8 rear from AirRide. (for a cheby, but adapted by me for the f100)..
it gets crowded with the triangulation bars..
Sam
Old 08-06-2008, 04:13 PM
BACAGrizz's Avatar
BACAGrizz
BACAGrizz is offline
I have the shockwave 8007 and universal triangulated 4-link which I am installing in my '56 F-100. If time is not of the essence and you have a little patience I will document the install beginning this weekend and let you know how it goes.
The whole setup was something in the neighborhood of $1200 (including a schrader valve kit for airing before installing the valves, tank, compressor, etc...).
Old 08-06-2008, 04:22 PM
sdetweil's Avatar
sdetweil
sdetweil is offline
Mine was like $850 7 years ago. 2 upper arms (since redone), and two lower arms, 2 airbags, 2 upper bag mounts. and some air line & fittings.
valves, compressor, switch extra. ($200)
if you use ONE set of valves left/right, then make sure you have a sway bar to stop the side to side movement of air from one bag to another (I didn't think of that!..)
Sam
JBravo's Avatar
JBravo
JBravo is offline
Alot of patience coincides with little money...
Old 08-06-2008, 04:25 PM
sdetweil's Avatar
sdetweil
sdetweil is offline
hence why my truck has taken 8 years..
Sam
Old 08-06-2008, 04:48 PM
havi's Avatar
havi
havi is offline
I'll have the Roast Duck
No truer words have been spoken.
No patience+no money=no progress.
Quick Reply: Fresh frame and rear suspension?
