Pyrometer install
Old Aug 5, 2008 | 07:02 PM
Firefighter 1406's Avatar
Firefighter 1406
Pyrometer install
Just to make sure I have this right. Tap into the drivers side exhaust and make sure there is grease on the tap. Do you put teflon tape or anything or just screw it in? I got a used guage and a brand new prob kit for $75.00. I thought it was a pretty good deal. Is there anything I am missing?
Old Aug 5, 2008 | 07:06 PM
King0581's Avatar
King0581
Start out with a smaller drillbit and work your way up to the size you need for the tap. Teflon tape would melt pretty easy and quick at 1200 degrees! Be careful how deep you tap the hole. Its a pipe tap so its tapered. Do not run the tap all the way into the manifold. Hope you get what I'm trying to say there.
Old Aug 5, 2008 | 07:09 PM
jhand124's Avatar
jhand124
Don't worry about the grease, just let gravity do it's job. Any little shavings are going to pass though the turbo, if any even get in there.
Good luck
Old Aug 5, 2008 | 07:11 PM
hucka1a's Avatar
hucka1a
I started with a small bit and worked my way up. I didn't use any grease, I did use a shop vac and vacuumed out the hole between switching bits. Also I did mine in the pipe rather than the manifold. Several guys on here have done it this way, and I figured it would be easier to tap.
Old Aug 5, 2008 | 07:32 PM
Pocket's Avatar
Pocket
Like the others have said, start with smaller drill bits on the manifold and work your way up in size. If you want to vacuum out shavings, you can, but it's not a big deal if you don't. Tap the manifold and just bolt up the pyro probe. No sealant or anything else is required.
Old Aug 5, 2008 | 07:39 PM
jhand124's Avatar
jhand124
I vacuumed mine out too don't have a clue if there was anything in there though, the manifold is pretty soft easy to tap.
Old Aug 5, 2008 | 08:15 PM
big poppa's Avatar
big poppa
I did mine the way the guys said above, no grease and start small on the bit size and work up to the tap. Said to use anti sieze but didn't have any and just installed. One thing i did just to be safe is i kept the probe wires away from the fuel lines and anything around them from touching. Zip tied. Even though the wire is insulated, just did it for personal reasons, good luck...
Old Aug 5, 2008 | 10:03 PM
BobBarry's Avatar
BobBarry
Just one thing; don't start out TOO small, or else you may break off a bit in the manifold.
You can start with a 1/4" drill, and then up to the size necessary for the tap. A sharp drill will cut through the cast iron in the manifold without much trouble.
Just back the tap out a 1/4-turn for every 1/2-turn in, and take your time.
Old Aug 6, 2008 | 02:22 AM
Fordbronco69's Avatar
Fordbronco69
Infidel
Drill Slow.
Magnet.
My $.02
Old Aug 6, 2008 | 07:30 AM
schmuly's Avatar
schmuly
I bought a babies butt off e-bay that was drilled for a thermocoupler last year. When I changed my up-pipe donuts I had to install it because the threads and casting on my original b-butt broke. I was also installing gauges for the first time so I hooked the thermo to the b-butt. It works great. (4months so far)
I have never read of anyone else doing this.
Is that spot a good alternative to mount the thermo?
I didn't mean to hihack this thread... only want to let you know that there is another place to mount the thermo for the pyro. (hopefully)
Colin
Old Aug 6, 2008 | 07:35 AM
BobBarry's Avatar
BobBarry
Colin
That would be a great spot, as it measures right near the inlet of the turbo; it's just a *little* inaccessible if everything is still bolted to the motor...
Old Aug 6, 2008 | 08:43 AM
superduty4x4's Avatar
superduty4x4
Colin
I think you're fine having it there. My pyro is in my driver's side up-pipe because the PO had a clamp-in pyro there that I removed and used to install the pyro that came with my gauge kit.
Old Aug 6, 2008 | 09:12 AM
danskool's Avatar
danskool
Go Bills !
Did mine excatly like this, It was very easy to get to.
When you tap, like said above, Tap a few turns,back out,tap a few turns.etc Work your way in. After about half way up the tap. I checked with fitting. Don't want to tap to deep or it will never tighten up. I made the thread big enough so the fitting was 3/4's of the way screwed in. Spot checking with the fitting constantly.
I had a tap socket. So i could use a 3/8 drive ratchet and extension so i could make sure i was tapping straight.
Wear Safety Glasses !!
3-Gauge Install Pictures
Old Aug 6, 2008 | 11:34 AM
BobBarry's Avatar
BobBarry
In place of a tap-socket, you may be able to use an 8-point socket on the larger square-drive taps. I found that the cheap $9.99 imported socket-sets often come with a set of 8-point sockets, which work well enough to do the trick. If you're using enough force to break one of those 8-point sockets when tapping a hole, then you're not doing it right.
Old Aug 6, 2008 | 12:34 PM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
Colin
Not sure I would put my thermocupler in the babies butt. What you are protecting is the pistons. I would put it as close to the pistons as possible. I don't think there would be a big enough difference in the temps to worry about. Just my .02
