SES no more
Old Aug 5, 2008 | 05:44 PM
jhand124's Avatar
jhand124
SES no more
Alright you would think this would be a good thing.
But I haven't done anything to cure the SES light due to low ICP when I mash my go pedale with the tuner on.
When I first installed the DP I would get SES light and it would stay on for about 2 mins now nothing.
Power seems the same, what do you think wouild keep it from coming on?
I don't have AE or anthing too pull codes with either.
Thanks
Old Aug 5, 2008 | 06:13 PM
F350-6's Avatar
F350-6
Did you burn the bulb out?
Old Aug 5, 2008 | 06:19 PM
jhand124's Avatar
jhand124
I knew some was going to say that, it comes on with KOEO.
Old Aug 5, 2008 | 06:30 PM
superduty4x4's Avatar
superduty4x4
Stars aligned? I got mine to go away too but actually did something to make it go away (new PCM and re-wire of GPR to say bye-bye to the Cali setup).
Old Aug 5, 2008 | 06:31 PM
F350-6's Avatar
F350-6
I didn't want to disappoint you.
Without a scanner, who knows. Did you recently change your oil? Maybe fresh oil is helping out the ICP pressure?
Old Aug 5, 2008 | 06:39 PM
UP_There's Avatar
UP_There
maybe it's just lucky? who knows........I've only made mine come on once since I got the DP
Old Aug 5, 2008 | 06:42 PM
big poppa's Avatar
big poppa
Mine only comes on when i mash on it with the red line unhooked from the turbo. You just changed your oil in your truck right Jason ?
Old Aug 5, 2008 | 06:49 PM
jhand124's Avatar
jhand124
Thanks everyone. It's been this way for months, I just was thinking about it on the way home today and thought if anyone had experienced this.
I used to be able to make it come on anytime I wanted, being an early bird and all. Then it just went away. I can't even get it to come on towing.
Old Aug 5, 2008 | 06:53 PM
superduty4x4
No love for the early bird? My truck isn't all gussied up like most on here, but the only thing that ever gave me an SES was a dead glow plug. 6637, 4" duals, wastegate deleted are about the only engine mods.
Old Aug 5, 2008 | 08:55 PM
jhand124's Avatar
jhand124
Any other thoughts on this, I find it odd...like somethings wrong. Or should I just not worry about it.
Old Aug 11, 2008 | 12:52 AM
jhand124's Avatar
jhand124
No worries then.
Old Aug 11, 2008 | 04:23 AM
ron's power stroke's Avatar
ron's power stroke
i use to set mine off all the time and clear the codes when it did...now that i dont clear them so much i havent had the light in quite some time...
