Bab Vibration
Old Aug 5, 2008 | 04:14 PM
randomhero1172's Avatar
randomhero1172
Bab Vibration
Hey guys, just got tires rotated about a week ago - since then this problem has gotten a little worse but wasnt present right after the rotation. I have a bad steering wheel vibration (the entire vehicle as well) ONLY betweem 30-39mph and ONLY on acceleration. Also getting quite a kick when putting it in reverse. Tranny issues?
Old Aug 5, 2008 | 04:18 PM
John311t's Avatar
John311t
Sounds like it could be a u-joint with another problem in your front suspension. Since the kick into reverse sounds like U-joint. Check the u-joint then check the front brakes and suspension parts.
Old Aug 5, 2008 | 04:33 PM
randomhero1172
Ball joints are bad, for sure. The u joints could be suspect. What are the chances are being a transmission?
Old Aug 5, 2008 | 04:42 PM
John311t's Avatar
John311t
Without any other problems I would say not really a chance. The ball joints being bad just explained the vibration you are getting. The kick(are you stating going from reverse to drive it make almost like a clunk and a kick noise), is more than likely a bad u-joint. If you are testing the u-joints on this truck, beware, on mine i had 2 bad u joints that you could not tell until the driveshaft was off. If it is the trans, let me know, I got a good builder that is kinda local to you, within a county of ya at least. I would not even suspect transmission right now.
Old Aug 5, 2008 | 05:11 PM
randomhero1172
Thanks a ton John - Reps left
