Sponsored by: Kumho
Replacing front brake hoses
Old Aug 5, 2008 | 01:49 PM
srercrcr's Avatar
srercrcr
If I remove the front hoses in my F150 4X2 and plug the line so all the fluid doesn't drain out, it seems to me I shouldn't have to bleed the rear brakes, that end would still be intact. Correct?
Old Aug 5, 2008 | 01:57 PM
andym's Avatar
andym
That's correct; however brake fluid is hydroscopic, meaning it absorbs water. Water in brake fluid = lines that rust from the inside out. This is why most manufacturers recommend a complete brake system flush every two years. If it's been that long, it's a good idea to do it anyway especially since you already have the fluid, bucket, and helper lined up.
