Bolt Sizes?
Old Aug 5, 2008 | 06:40 AM
danlee's Avatar
danlee
Bolt Sizes?
I am assembling a 408 motor, and I don't have a lot of the small hardware because it was used on my 434. I need the bolt size for the camshaft bolt and the oil pump bolts. I also need the size for the Woodruff Key.
Can anyone supply this information?
Old Aug 5, 2008 | 03:12 PM
80broncoman's Avatar
80broncoman
Cam bolt is 3/8 NC x 2 with 1 1/8th threaded. The special washer behind it is .412 I.D. x 1.200 O.D. x .250 thick.
The oil pump bolt is 3/8th NC also and is 1 1/4 long and uses a lockwasher.
Old Aug 5, 2008 | 06:27 PM
danlee's Avatar
danlee
Thanks. I'll try to pick up something close tomorrow.
I think that the Woodruff key is 3/16" width. I'll try a couple different sizes.
Old Aug 8, 2008 | 12:17 PM
mustang81's Avatar
mustang81
woodruff keys. A 3/16-inch x 1-3/4-inch key is used at the sprocket and the other, a 1/4-inch x 7/8-inch key is used at the crankshaft damper.
Old Aug 16, 2008 | 04:13 PM
danlee's Avatar
danlee
I got a the bolt, washer and woodruff key from Tim Meyer, but my crank only has one woodruff key slot. It's the 3/16 x 1-3/4. That one key picks up the timing chain sprocket and the damper.
I do have a question about that. The woodruff key only goes part way into the sprocket.
Curjo
Oct 16, 2014 05:34 PM
joe f350
Feb 28, 2013 10:30 PM
scottlane
Apr 4, 2007 07:06 PM
04superduty
Sep 25, 2004 01:51 PM
72RangerXLT
Sep 18, 2002 10:35 PM
