Injectors are not injecting!! Why???
Old Jul 22, 2002 | 09:17 PM
psualumnut's Avatar
psualumnut
My truck won't start!!! 88 F150 5.0 HO block.
There is pressure in the fuel rails, truck turns over fine, firing order is correct, timing is correct.
when attemping to start...acts as if there is no fire. i checked the plugs after trying to start...
they were dry. it seems to me that the injectors are not injecting!!
What could cause this??
oh..the injector wiring harness is plugged in and grounded. i don't know what else to look for.
Thanks for all the info.
Jared PSU tailgater
Old Jul 22, 2002 | 09:47 PM
Mil1ion's Avatar
Mil1ion
Try posting that question here.
http://www.ford-trucks.com/cgi-bin/d...ID76&conf=misc
Old Jul 23, 2002 | 12:11 AM
Mil1ion's Avatar
Mil1ion
Old Jul 25, 2005 | 09:52 PM
Blom's Avatar
Blom
Cool Injectors are not injecting
I have a 1989 Ford F-150 6 cylinder with fuel injection and
I am having the same problem. IF ANYONE CAN HELP US
IT WILL BE APPRECIATED.
K.E.BLOM
Old Jul 25, 2005 | 10:57 PM
FSC's Avatar
FSC
The computer grounds the injectors to fire them, the computer is grounded at the negative battery terminal.
You can see if the injectors are firing with a noid light, lacking that, you can back probe an injector plug with a voltmeter or test light.
In cranking mode, one side of the injector will be a steady 12v, the other side will blink, if you have voltage on both sides and it does not blink, the computer is probably bad, if you have no voltage, check the fuses, EEC relay and wiring.
Old Jul 26, 2005 | 06:35 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome Blom, to Ford Truck Enthusiasts! Please read the Guidelines, it will help you to navigate through and understand this site.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old Jul 27, 2005 | 10:04 AM
Franklin2's Avatar
Franklin2
The first thing I would do is pull a plug wire off, stick a screwdriver up in the wire, and while holding the screwdriver by the plastic handle, get someone to crank the truck while you have the metal part of the screwdriver very close, but not touching a piece of metal on the engine block. You should get a nice blue spark.
If you don't get a spark, the next thing I would do is pull the distributor cap off, and while cranking the motor, make sure the rotor is turning. This is really important for the six cylinder guy, since I have heard of two of these engines now, stripping the teeth on the timing gear(it's phenolic material).
If the rotor is turning, but you still have no spark, I would try the ignition module mounted on the dist. The module sends pulses to the computer to let it now when the engine is turning and also timing info. If there are no pulses from the module, then the computer is not going to fire the injectors.
