Sponsored by: Real Truck
climate control went out
Old Aug 4, 2008 | 08:24 PM
dutydave's Avatar
dutydave
Got in the truck this morning fired her up and the climate control was blank. I dove to the coffee shop shut her down and when I fired her back up again it was working. Anyone else have this problem?
Old Aug 4, 2008 | 08:35 PM
wiingnut's Avatar
wiingnut
Had the issue in my 05 350 and my 05 explorer. Seemed like a brainfart, then everything worked fine. They did however, replace once in both vehicles.
Old Aug 5, 2008 | 09:15 AM
rhodeisland350's Avatar
rhodeisland350
Yah, same thing has happened to me in mine since i've owned it (Feb 08). First time it happened to me i checked everything i could think of and couldn't figure it out. Got in it figuring i'd have to send it off to the dealer and turned the key and what do ya know it works, i can't figure it out.
Old Aug 5, 2008 | 09:25 AM
castrol's Avatar
castrol
Had it happen to me last week. I panicked. It's been in the 100's here and with a black truck,
no a/c is unacceptable. I was immediately thinking huge dealer bill, and then it came back
on. I was quite relieved, although I notice that my exterior temp gauge is acting funny now.
Old Aug 5, 2008 | 12:23 PM
GregsSD's Avatar
GregsSD
Mine has done it twice in the last 1-1/2 years and both times it came back on after I turned off the truck for a minute.
I have also heard that you can turn the headlight switch to auto then back to on or off and that will reset it.
Old Aug 5, 2008 | 09:45 PM
fordboy2's Avatar
fordboy2
I have been told the climate controls have issues and will eventually go out completely. Mine also has done this once, intersting enough the only time i hear people having problems is when it is really hot out, must be heat oriented.
Old Aug 6, 2008 | 05:32 PM
Beerstalker's Avatar
Beerstalker
Known issue. There are some relays in the electronic climate control system that will get stuck. Usually shutting the truck off and restarting it, or turning the headlights on and off will get it to start working again. However, after a while it will stop working altogether and you will have to replace the unit. I recommend getting it replaced as soon as possible if you are under warranty as it is not a cheap part ($300+ if I remember right). Whenever it stops working just drive to the dealership and leave the truck running and have someone come out to see that it is dead. Chances are if you shut it off, it will start working when the guy comes out to look at it.
