Just want to be sure........
I am in process of changing fluid on my tranny and am lined up with a small bolt head on the torque convertor once I removed the rubber plug. I am unsure, because the bolt head is rather small and I guess I could rotate to be sure, but the bolt head was there when I pulled plug. So don't want to have to find it again if it is tricky.
So....is this in fact the drain plug?
Hey MarK, thanks for the reply. I managed to find a photo online that showed a TC out of the transmission and a clear shot of the plug. It just seemed too small to be a drain plug. Anyway...all went well. Fluid, filter and gasket change.'
No noticeable difference but the oil looks much better.
Thanks again!
