best glow plugs ??????????
Old Aug 4, 2008 | 10:09 AM
a711112a's Avatar
a711112a
what does every one think?
what brand of glow plugs are the best?
Old Aug 4, 2008 | 12:09 PM
Lazy K's Avatar
Lazy K
Everyone on here will tell you the same, Motorcraft or Beru only. And they are right.
Old Aug 4, 2008 | 01:38 PM
David85's Avatar
David85
+1
There may be some dual coil glow plugs that are in theory safer even than Beru, but so far I can't find any of them localy, so I can't vouch for them.
Beru, acceptable
Bosch, sort of OK
Autolite, very bad
Wellman, very bad
Champion, also very bad
There are two major differences that make the beru plug better.
1) it heats up slower
2) if it does burn up, it will not swell up like the others and become impossible to remove or worse yet, burn the glow plug tip off completely.
This is an example of the best case scenario when a glow plug tip gets passed out the exhaust (my engine):
Others were not so lucky.
Its also recommended to test the glow plugs before installing them by heating them up for 10 seconds.
Old Aug 4, 2008 | 01:48 PM
LCAM-01XA's Avatar
LCAM-01XA
We installed a set of AC Delco slow-glow plugs (12V units for a 5.7 Olds diesel) in my buddy's '86 F250, they don't seem to work good as they take forever to heat up and even then truck still has hard time firing up. He just purchased 5 Motorcraft/Beru ZD1s, once we got the remaining 3 to complete the set the Delcos are coming right out.
Old Aug 4, 2008 | 02:05 PM
David85's Avatar
David85
We have the OEM AC delcos in my dad's GMC and they seemt to be holding up well over the years. Its a 1993 6.5 turbo.
Glow time seems to be higher in cold weather. Up to 12 seconds, my truck will never glow for longer than 10.
Old Aug 4, 2008 | 03:47 PM
FORD MEGA CAB!!!'s Avatar
FORD MEGA CAB!!!
I would also go with the motorcraft, beru as well.
Old Aug 5, 2008 | 06:02 PM
snubber's Avatar
snubber
I tried Autolite, before i joined this forum.
I was lucky, 2 of them stopped working within 2 months, was able to get them out without leaving the tips down there.
I replaced them with BERU plugs 3-4 years ago, and they are still working good....
Old Aug 5, 2008 | 08:16 PM
a711112a's Avatar
a711112a
i was looking at the heads off a 6.9 i was going to rebuild. It has beru glow plugs.
has any one come up with a way or adapter to use the spade glow plugs in a later model 7.3l with bullet tip connectors? i want to use them as my budget is tight but i dont want to cut the wires to make them work
Old Aug 5, 2008 | 09:57 PM
Dave Sponaugle's Avatar
Dave Sponaugle
Last time I checked both ZD 1A (spade) and ZD 9 (bullet) were both the same price.
Old Aug 5, 2008 | 10:21 PM
a711112a's Avatar
a711112a
i have the spade ones in hand.... i will save up and buy the bullit ones ....thanks for the help dave.
Old Aug 5, 2008 | 10:58 PM
S.P.'s Avatar
S.P.
I will say, I have Autolites in my truck, had them in for over a year with no problems , now I have a stuck injector and am pulling the heads...so maybe I will go find me some ZD 9 plugs.....just to be on the safe side
keepnthepeace
Nov 28, 2010 11:41 AM
Mike Ch
Sep 26, 2010 09:16 PM
hogdogs
Dec 11, 2008 01:40 AM
getnbz
Jun 20, 2008 03:55 PM
PAVEMENTMAN
Feb 10, 2008 08:59 PM
