Courtesy door switch ?? and 92-96 Flareside Tonneaus!!
My dome light won't come on when I open my drivers side door, but it does when I open the passenger side, so I'm assuming this switch
is bad. Any part number or idea on what one costs? Hopefully it's not a "You can only get it from Ford for big $$$" parts like I already encountered once...
https://www.ford-trucks.com/forums/7...cab-steps.html
*******ALSO********
While searching for info I found most everyone with the Flaresides has a hard time finding a tonneau for them, I'm found 2....
and here are links to the best prices I've found on them
Advantage Sure-Fit Tonneau Cover
Downey SST (Slant Side) Tonneau Cover
Not advertising for that site, just know that I've had a hard time finding these anywhere, let alone at a decent price.
I always seem to get the stuff with hard parts to find, The Flareside and my Mustang, which is more of a case where everything is more expensive because it was only 2 model years.
*******ALSO********
not sure about the light switch,but here is where the bed cover came from that is on my 95 flareside A.R.E. : Manufacturer of fiberglass pick-up truck caps, truck canopies, tops, toppers, camper shells, hard tonneau covers, work caps and truck accessories.. the truck came with the cover on it,so I can't tell you how much it costs,but it does seem pretty sturdy,it is made of fiberglass. Not real sure I am going to leave it on my truck. It is nice when me and the kids are camping,keeps the gear dry,but it is a pain in the neck when I want to haul something.
Good find on those Flareside tonneau covers! Four years ago when I bought my 92 Flareside, I had a very hard time finding a tonneau cover for it. I ended up having to have one special ordered from a local truck accessories shop( and it was fairly pricey!)
As far as the courtesy door switch, I don't know how much it would be from Ford, but it would definitely be cheaper if you were able to find one on a truck in a junkyard. I think those switches were the same from 1987-96.
I actually ordered it from Advanced Auto today, for $23. Also ordered one of the tonneau covers, also have a new grille and headlight doors on the way. The bug shield that was on the truck when I bought it had drain holes in it, which let the water run down the grill wearing big lines off the chrome. Just finished putting a new engine and a computer in. Next up is dual exhaust and I think that's it.
Unless someone knows where I can find this bar on the front bumper..
Hillie16, Sweet Flareside. Have one like it, just no grey stripe. Had the same problem, with the dome light; r&r'd the switch, nothing just like yours. I traced the wiring down, and found that where the installer of the alarm (that was in the truck when I got it) spliced into the drivers dome light switch. Over time the splice connection wore thru the wire completely, causing a 'short' in the wire. (for lack of a better word) Hope this helps.
