Ignition control
Old Jul 10, 2002 | 09:28 AM
Brian460's Avatar
Brian460
Ignition control
Tell me if I am right. Does the red and white wires that go the the firewall off of the ignition control box hook up to the ignition switch hot and the ground
Old Jul 10, 2002 | 10:55 AM
Mil1ion's Avatar
Mil1ion
Ignition control
I don't know.
Knowing what vehicle you are enquiring about would help.
[font color=red]Dennis
FTE Adminstration
[/font]
http://www.clubfte.com/users/mil1ion/canada_flag_animated.gif
[link:www.clubfte.com/users/mil1ion/Mil1ion.html|My Website,"North Of The 49th"]
[link:www.ford-trucks.com/guidelines.html|Club FTE]
http://www.clubfte.com/users/mil1ion/Minimorleytruck.JPG
[font color=blue]78 F-150 429CJ,Silver,Explorer Pkg.
[/font]
Old Jul 10, 2002 | 11:13 AM
Brian460's Avatar
Brian460
Ignition control
Sorry I forgot that. The wiring is from a 79 bronco, but I am installing it in a 91 f-250 that previously had a diesel.
Thanks Brian
Old Jul 10, 2002 | 11:43 AM
Mil1ion's Avatar
Mil1ion
Ignition control
The 79 wiring doesn't show a RED by itself.
There is a Red/Blue wire going to the Ignition switch.
There is a white all by itself.That goes to the ignition module from the ignition switch.
FTE Adminstration
[/font]
[/font]
Old Jul 10, 2002 | 02:29 PM
Brian460's Avatar
Brian460
Ignition control
Perhaps a wiring diagram would be helpful. I went out and looked and it is a red w/ blue stripe and a white wiring. So they both go to the ignition switch is so what current do they get and when like when the key is on and when it is cranking are they both + wires .
Thanks for your help Brian
:-X11
Old Jul 10, 2002 | 05:52 PM
Mil1ion's Avatar
Mil1ion
Ignition control
Okay, This is the part where I need you you to e-mail me directly and I in turn reply with the Ignition switch continuity test.
So you in turn can print it and refer to it when you use your Multi-meter on it.
FTE Adminstration
[/font]
[/font]
Old Jul 10, 2002 | 06:30 PM
sparky's Avatar
sparky
Ignition control
>:-X11
The white wire needs 12 volts when the ignition switch is in "start" and the red/blue wire needs 12 volts when the switch is in "run".
If I remember correctly the white wire retards the timing for start-up and the red/blue wire is 12 volts to the ignition module for normal running.
Sparky
Old Jul 10, 2002 | 11:31 PM
Brian460's Avatar
Brian460
Ignition control
Where would the resistor be located or is this a generic wiring diagram? I thought that the Ford coils had the resistor built in.
The diagram did answer my question one wire is hot while running and the other is hot while cranking.
Thank you for your help
Old Jul 11, 2002 | 02:28 AM
sparky's Avatar
sparky
Ignition control
The diagram is generic but pretty much correct The ballast resistor is actually a wire running from the ignition switch to a splice by the firewall in front of the drivers knee area.
It is pink with a black stripe, well normally it is a burnt black color from the heat
Since you are installing this engine in a former diesel powered truck it most likely wont have this wire. So get a ballast resistor from a chrysler product, that is about 1.3 to 1.7 ohms. That will drop the voltage to the coil down to 7-9 volts for constant running.
Sparky
Old Aug 4, 2002 | 09:54 AM
tallica2002's Avatar
tallica2002
Ignition control
ok I am having the same question so your telling me there is not really a ballast resistor it is made into the wire
Old Aug 4, 2002 | 11:35 AM
Maverick494's Avatar
Maverick494
Ignition control
