Battery Gauge
Old Aug 5, 2002 | 10:14 PM
LonnieD's Avatar
LonnieD
Battery Gauge
Thgis isn't on my Ford, but it still should be just a regular question to fit all:
What does it mean when you turn-on your turn signals and the battery gauge blinks along with the turn signals (the needle moves back and forth)or shows a loss of gain of a charge when the engine is on? This has naver happened to me beofre. Is it a weak alternator or battery getting Weak?
Lonallie@cs.com
lonnie.dotson@boeing.com
Old Aug 5, 2002 | 10:38 PM
Mil1ion's Avatar
Mil1ion
Battery Gauge
Time to clean off all the grounds.
It means some (little bit more) current is going to ground than normal.
It could also mean the Voltage Regulator needs cleaning where it mounts.
Does it do this with engine revved up a little?
http://www.clubfte.com/users/mil1ion/2cents.gif
[font color=red]Dennis
FTE Assistant Administrator
[/font]
[link: motorhaven.autoanything.com|How YOU Can Support This Site]
http://www.clubfte.com/users/mil1ion/canada_flag_animated.gif
[link:www.clubfte.com/users/mil1ion/Mil1ion.html|My Website,"North Of The 49th"]
[link:www.ford-trucks.com/guidelines.html|Club FTE]
http://www.clubfte.com/users/mil1ion/Minimorleytruck.JPG
[font color=blue]78 F-150 429CJ,Silver,Explorer Pkg.
64 1/2 Mustang Pre-World's Fair Car #8092
68-Mustang 289 2v-Sunlit Gold
[/font]
Old Aug 5, 2002 | 10:41 PM
LonnieD's Avatar
LonnieD
Battery Gauge
Not sure Dennis, I just noticed while daughter was driving that the needle moved each time she used any type of electrical device...I thought maybe the battery was getting weak or the alternator was going bad...
Lonallie@cs.com
Old Aug 6, 2002 | 09:44 PM
Mike W's Avatar
Mike W
Battery Gauge
It is probably doing this because the voltmeter is hooked to some wire far from the battery. As the wire supplies current to some accessory, the voltage drops. You could test with another voltmeter right at the battery. If the alternator is working ok, the battery voltage will probably show little or no change as you turn on different devices.
Old Aug 6, 2002 | 11:21 PM
Mil1ion's Avatar
Mil1ion
Battery Gauge
gcspray
Oct 26, 2013 04:45 PM
royzell
Oct 18, 2009 12:40 PM
LonnieD
Jan 19, 2006 05:00 PM
LonnieD
Nov 4, 2002 10:56 AM
