Code P0401
Old Aug 3, 2008 | 04:36 PM
rickyjperez's Avatar
rickyjperez
Code P0401
I have a 2000 ford expedition and I have replace all gaskets in the manifold and check engine light still comes on, I have replace all egr part except for the egr position sensor. Does anyone know if that goes out as my check engine light stays on
Old Aug 4, 2008 | 11:18 AM
pdqford's Avatar
pdqford
What code, if any, is currently set?
Old Aug 4, 2008 | 11:37 AM
rickyjperez
The code is P0401
Old Aug 4, 2008 | 11:43 AM
kailor's Avatar
kailor
P0401 Insufficient EGR Flow.
I would completely remove the throttle body and clean all ports out.
I would also check for a cracked elbow (trace from pcv valve to back of intake/throttle body) behind the intake manifold.
Old Aug 4, 2008 | 11:45 AM
pdqford's Avatar
pdqford
My guess would be the DPFE, but depending on the miles on the vehicle you may have some carbon build up in the EGR passages.
But wait! You had the intake off to replace the gaskets: how did the EGR passages look?
Old Aug 4, 2008 | 11:48 AM
rickyjperez
it was clogged and we cleaned off and already replaced the DPFE
Old Aug 4, 2008 | 01:07 PM
KingRanchMan02's Avatar
KingRanchMan02
This thread is a good discussion on the P0401 DTC. Also, do not use aftermarket DPFE sensors. Motorcraft only as the aftermarket ones do not get updated like the new parts from Ford. Good luck!
https://www.ford-trucks.com/forums/248921-diagnostic-code-p0401-insufficient-egr-flow.html
Old Aug 4, 2008 | 01:13 PM
rickyjperez
ok i will try the ford part as i have replaced the dpfe twice but after market
Old Aug 8, 2008 | 10:06 PM
rickyjperez
OK i have put the DPFE from Ford and lets see what happens.
Old Aug 9, 2008 | 12:57 PM
a64armt's Avatar
a64armt
If the problem returns, see if these pages help.
http://home.coastalnow.net/~a64armt/...401/Slide1.JPG
http://home.coastalnow.net/~a64armt/...401/Slide2.JPG
http://home.coastalnow.net/~a64armt/...401/Slide3.JPG
http://home.coastalnow.net/~a64armt/...401/Slide4.JPG
http://home.coastalnow.net/~a64armt/...401/Slide5.JPG
Having a multimeter and vacuum pump/gauge will make quick work of the 401 code. Since you say you replaced most components in the system, I am betting you have a broken vacuum line or a clogged EGR passage.
I had a broken vacuum line up against the passenger firewall when I wrote these proceedures.
Vincent
Old Aug 10, 2008 | 10:58 AM
pdqford's Avatar
pdqford
Vincent, Very nice write up........
davenpt
2004 - 2008 F150
21
Jul 7, 2014 01:33 PM
timbo65
22
Aug 18, 2007 01:15 PM
lm1d
1997 - 2003 F150
Dec 1, 2004 12:01 PM
dcale101
1983 - 2012 Ranger & B-Series
30
Nov 19, 2004 06:05 PM
opie1938
Feb 23, 2004 02:50 PM
