Is it possible to change my bendix ps box over to a ford(saginaw) box easily??? i hate the bendix box...drips like crazy. and its really expensive to replace and they dont make seal kits for it... can i drop take out the bendix and drop in the ford? or is it a lot more complicated than that???
Yes you can. You will need to exchange everything as the two systems are completely incompatible. When I say everything, I mean gear, pump, steering column, hose/lines, and brackets.
You will do basically the same as if you didn't have power steering currently.
my truck came stock with the disc brakes option. so with the newer 73-79 half ton. could i just bolt that steering right up and it would workwith the bendix setup i have, or is there some fab work i would have to do??? cuz i really dont wanna find or buy another bendix box
Dan, Disregard the half ton in my last post. 76 was the last year the FE was used. Saginaw power steering from a 100/150-250 is the same. The Bendix gear is identical to the manual in size, some folk like to use it because it is. The Saginaw gear has the fluid lines on top and requires a setup matching shorter column. Most here feel the Saginaw system is far better and use it.
A seal kit could be a easy solution for the leaking.
but can you move the column up to make up for the size ??
No to just moving the column up 2 3/8" You can use the 73-79 column or you can shorten your column shaft if your skill level is high enough. Not an easy job.
John
Unless you already paid an arm and leg for that expensive borgenson shaft, which telescopes. I think. But correct me if I'm wrong.
