Tire Pressure Sensor
Old Aug 3, 2008 | 11:08 AM
Vegas Ernie's Avatar
Vegas Ernie
Can anybody tell me the where the tire pressure sensor is located on a 2004 Mountaineer. Wife wont drive it and that means she wont go to work till I can get this issue corrected. Thanks
Old Aug 3, 2008 | 12:07 PM
9explorer8's Avatar
9explorer8
She won't drive it 'cause the automatic tire pressure sensors are not working? Wow, and I thought I was married to a high-maintenance
woman!
Old Aug 3, 2008 | 01:03 PM
Vegas Ernie
She is convinced that the tire will go flat because the pressure sensor says the tire is low, never mind the fact that is hasnt lost a pound of pressure. I am not sure is there is one sensor on each wheel or if there is some sort of mercury switch that sends a signal if there is a slight tip to the vehicle.
Old Aug 3, 2008 | 01:21 PM
9explorer8's Avatar
9explorer8
Ernie,
Wish I could help you with that problem, but my vehicles are older and don't have that feature. It is a good safety feature, though. Let us know what you find out about your problem and how you fixed it. It will probably be a standard feature on all cars and trucks soon and something we will all have to deal with.
Good luck
JD
Old Aug 3, 2008 | 01:29 PM
9explorer8's Avatar
9explorer8
Found this:
Direct Systems
attach a pressure sensor/transmitter to the vehicle's wheel inside the tire's air chamber. An in-car receiver warns the driver instantly if the pressure in any one tire falls below a pre-determined level.
Indirect Systems
use the vehicle's antilock braking system's wheel speed sensors to compare the rotational speed of one tire vs. the others. If one tire is low on pressure, it will roll at a different number of revolutions per mile than the other three tires, and alert the vehicle's onboard computer.
JD
shelby67air
Aug 18, 2015 08:28 PM
boilerperson
Sep 16, 2012 08:36 PM
026TB4U
Dec 19, 2010 10:28 AM
expedite mike
Nov 30, 2010 10:11 AM
mantta
2009 - 2014 F150
Jul 10, 2010 06:54 AM
