interesting project
Old Aug 3, 2008 | 12:07 AM
f-420's Avatar
f-420
interesting project
what transfer cases are copatible with c6 transmition??
what transmitions are compatible to a 351m??
87 ranger with 6 inch suspention 3 inch body lift
has original c4 trans with c5 adapter to conect to 1350 transfer case....i need advise on wether a c6 will be compatible with 1350 transfer case or if 351m will bolt up to c4 trans...if not will a 205 be a hard install.....small truck big plans..need advise
Old Aug 3, 2008 | 12:30 AM
80broncoman's Avatar
80broncoman
I'm unsure if the C-6 will bolt to the BW1350 case. With a 3 inch body lift I can't see a NP205 being that hard to install.
Old Aug 3, 2008 | 12:05 PM
acct21's Avatar
acct21
Automatic transmissions that fit the 351M/400
C6
E4OD/4r100
FMX (if you can find the 351M/400/460 bell housing)
There is a $700 adapter plate that will allow you to hook up any "small block" tranny, like the C4.
One option is to go 351M/C6/NP205. Another option is to go 351M/C6/Dana 20. Advance sells an adapter for the C6 to Dana 20.
