C6 Cover Plate Needed
Old Aug 1, 2008 | 08:27 PM
danlee's Avatar
danlee
I'm rebuilding my 408 motor with 351C-4V closed chamber heads. I plan to start it and run it in a test stand, but I need a place to mount the starter.
Does anyone have a C6 cover plate, that they can part with?
I also need a set of 351C-4V manifolds or headers.
Old Aug 3, 2008 | 10:57 AM
classicranger's Avatar
classicranger
If you have the trans you can bolt the trans to the engine without the torque converter and mount the starter, or if you have a manual trans bellhousing to bolt to it would be easier. Just an idea
Old Aug 3, 2008 | 01:04 PM
danlee's Avatar
danlee
I don't have a trans or a bell housing. I don't even have a vehicle to put the motor into. Someone is sending a cover plate, and also a flexplate with bolts etc.
I think that I can mount the starter to the cover plate without the bell housing. The starter has two ears. I think that one bolts to the bell housing thorught the cover plate and the other bolts through the cover plate to the threaded hole in the starter. I will put a nut where the bell housing should be. I may have to reinforce those holes with a piece of steel bhind the plate, but it should work without a bell housing.
I may have to buy a cheap set of 4V headers, then sell them on ebay if I can't use them on a vehicle.
F&M
Jan 16, 2014 04:41 PM
buttnuttn8
Sep 11, 2004 02:28 PM
loudfords
Jul 13, 2004 11:36 AM
