electronic ignition
The theory I have heard, and believe, about it is: it is used to reduce the running voltage to the coil to extend its life and the life of the points if the truck has points.
Sparky
>the 302 from that truck into a 67 and wanted to know how to
>wire it.
Does the 67 have all its original wiring, or better yet did you or are you removing the engine from it to install the 302???
The 67 should have all the wiring you require. Everything hooks up to the + of the "new" coil the same as to the old coil. All the other wires are in the duraspark harness on the 302.
You merely have to hookup two wires to the duraspark module.
A wire that has 12 volts when the key is held to "start" to the red wire. Could be a red/blue striped wire, if you cant find it run a new wire from the "I" terminal of the start relay.
And one that has 12 volts when the key is in "run" to the white wire. You will have to search around for a suitable wire, or tap into the igniton switch to get the correct 12 volts with key to "run" only.
Hope this explains it.
Sparky
I got one for ya. I spliced my resistance wire and am wondering if I did a big no no! What do you think?
Russell
1968 F250 LWB 300-6
FORD=First on Race Day
#88 Dale Jarrett
#21 Elliott Sadler
#97 Kurt Busch
#28 Ricky Rudd
The factory resistance is supposed to be 1.05-1.15 ohms, well according to the book I have
So since I cant remember how long the wire is and if you have a rough idea.... divide the resistance by the wire length in inches to get a resistance per inch. Then measure the amount you removed and multiply it by the resistance you calculated per inch. Then subtract that from 1.15 and see how close it is to the 1.05-1.15 window.Also with this type of wire you really have to have a good splice, dont want to have a higher resistance caused by a bad connection :-X23
Sparky
If it burns up the coil I will run my own wire with a 1 ohm resistor in series with it. Got plenty of those things sitting around the shop at work.
Russell
1968 F250 LWB 300-6
#88 Dale Jarrett
#21 Elliott Sadler
#97 Kurt Busch
#28 Ricky Rudd
Way better idea, IMHO anyway. I usually do this to the trucks I get. Had a resistor wire burn up once and took most of the other wires close to it out also. Boy did that truck ever do werid stuff before I figured out what happened. Turn on the key the wipers started, turn on signal lights radio came on :-X23 All that was left was one big black wire clump with everything shorted to everything where the harness behind the instrument panel used to be.
Make sure the resistor is able to handle the heat...that is why I use a Chrysler ballast reistor and carry a spare as they can be a little unreliable.
Sparky
>Sparky
Thanks for the info. I know all about installing a too low wattage rated resistor. Took out a $40,000.00 circuit board doing that once. Oops. Thank goodness I was new to electronic's at the time! Anyways thanks for the info again. I think I may pull my resistor wire away from the bundle and run it outside from all the rest of 'em.
Later,
Russell
1968 F250 LWB 300-6
#88 Dale Jarrett
#21 Elliott Sadler
#97 Kurt Busch
#28 Ricky Rudd
