Sponsored by: Real Truck
changing rear view mirror
Old Aug 2, 2008 | 04:43 PM
getnbz's Avatar
getnbz
i am changing out the OE mirror for a billet mirror they dont come off like the old cars with an allen screw and slide off. i looked at the ford service manual for the procedure and it says you need a special tool to remove it. has anyone done this can you fill me in on the job.
thnx
Old Aug 2, 2008 | 06:56 PM
fsholder's Avatar
fsholder
I had to pull mine off a couple of weeks ago when I tinted my windows. It just has a compression fitting that you have to mess with till it just slides up toward the roof. Good luck.
Fred
Old Aug 2, 2008 | 07:26 PM
getnbz's Avatar
getnbz
how did you get it off pry it or what
Old Aug 3, 2008 | 12:44 AM
fsholder's Avatar
fsholder
Pull out on the bottom with a pick or small screwdriver while you push it upwards on the base. It's kinda tricky and I had to mess with mine a good 15 minutes before I figured out there was no set screw in it.
Fred
Old Aug 21, 2010 | 10:57 PM
kwidav's Avatar
kwidav
ford has a special tool to remove it. i got mine off with a .028 feeler guage. you have to file about a 1/8" off the side of it because its to wide. then just slide it in the hole in the bottom of the mirror.wiggle the mirror side to side wile pushing up on it. should pop right off.you can get the feeler guage at sears or any auto parts store for about 6 bucks.
Archimandrite
Dec 1, 2014 05:34 PM
ZFamly
Aug 26, 2010 02:06 PM
cvfdfighter414
2004 - 2008 F150
Jan 7, 2010 06:07 AM
FE352
Jul 22, 2009 12:12 PM
Rick2001
6.4L Power Stroke Diesel
Jan 13, 2008 08:21 PM
