early 99 upgrades?
Old Aug 9, 2008 | 02:10 PM
dmncoon's Avatar
dmncoon
I haven't the slightest clue what type of PCM to look for. What all do I need to know
Old Aug 9, 2008 | 03:21 PM
pmbmax's Avatar
pmbmax
I agree how do you tell what is on your truck? My truck was built in 4 of 99 and is hard to start and is not very smooth and shifts strang somtimes.
Old Aug 9, 2008 | 05:28 PM
ron's power stroke's Avatar
ron's power stroke
you should have the right PCM..your truck is a 99.5 truck,, the end of the early bird was 12/7/98 but here is how you check for your PCM code
http://www.dp-tuner.com/documentatio...PCM%20Code.pdf
you will want one of these PCM's..if you have a auto trans..you need a PCM for auto trans,,
your early bird PCM can not be re flashed with what you are looking for...
All of these can be used however it may need to be reflashed depending on the PCM code you want.
PSD ONLY
YEAR VEHICLE ENGINE TEMPLATE ECM PART # CALIB MODL TYPE SIZE CSUM CODE APPLICATION MODULE APPLICATION
1999 F-Series 7.3L DI TC VJAE3R2 XC3F-ND 9DTA-ARB DPC-422 216 A915 FIF2 PHN131 50S/AUTO/COLD
1999 F-Series 7.3L DI TC VJAE5S2 XU2F-ABA 9DTA-ASC DPC-422 216 F043 RXM0 P131 SERVICE
1999 F-Series 7.3L DI TC VJAE3S5 XC3F-ERD 9DTA-ASC DPC-422 216 9052 AGD3 P131 50S/WARM/AUTO
1999 F-Series 7.3L DI TC VJAE3S3 XC3F-RD 9DTA-ASB DPC-422 216 9721 AGD2 PHN131 50S/AUTO/WARM
1999 F-Series 7.3L DI TC VJAE1S4 XC3F-RC 9DTA-ASA DPC-422 216 E8 AGD1 PHN131 50S/AUTO/WARM
1999 F-Series 7.3L DI TC VJAE0S2 XC3F-RB 9DTA-ASA DPC-422 216 7B1A AGD0 F450/550/560 50S/A/T/WARM WEATHER
1999 F-Series 7.3L DI TC VJAE7R2 XU2F-ZC 9DTA-ARC DPC-422 216 E02A YEV2 P131 N/A
1999 F-Series 7.3L DI TC VJAE6R4 XU2F-ZB 9DTA-ARC DPC-422 216 E435 YEV1 P131 F250/350
1999 F-Series 7.3L DI TC VJAE5R3 XU2F-ZA 9DTA-ARC DPC-422 216 C964 YEV0 P131 SERVICE
1999 F-Series 7.3L DI TC VJAE1R4 XC3F-NC 9DTA-ARA DPC-422 216 F7CF FIF1 PHN131 50S/AUTO/COLD
1999 F-Series 7.3L DI TC VJAE0R2 XC3F-NB 9DTA-ARA DPC-422 216 8A11 FIF0 F250/350 49S/A/T/WARM WEATHER
1999 F-Series 7.3L DI TC VJAE3R4 XC3F-END 9DTA-ARC DPC-422 216 A345 FIF3 P131 FED/WARM/AUTO
1999 F-Series 7.3L DI TC VJAE6S4 XU2F-ABB 9DTA-ASC DPC-422 216 0819 RXM1 P131 F450/550
2001 F-Series 7.3L DI TC VRAA7W3 1C3F-ATB 1F719W0A10 DPC-422 216 681E JLJ1
2001 F-Series 7.3L DI TC VRAA7W2 1C3F-ATA 1F719W0A00 DPC-422 216 681C JLJ0
2001 F-Series 7.3L DI TC VRAA7T6 1C3F-ADD 1F719T0A11 DPC-422 216 6703 BKA3
2001 F-Series 7.3L DI TC VRAA7T5 1C3F-ADC 1F719T0A10 DPC-422 216 6700 BKA2 450/550 A 4.88 50S P131/U137
2001 F-Series 7.3L DI TC VRAA6T3 1C3F-ADB 1F719T0A05 DPC-422 216 2F95 BKA1 P131 N/A
2001 F-Series 7.3L DI TC VRAA4T4 1C3F-ADA 1F719T0A00 DPC-422 216 1FE2 BKA0
2001 F-Series 7.3L DI TC VRAA7S6 1C3F-ZD 1F719S0A11 DPC-422 216 5A0A PMT3
2001 F-Series 7.3L DI TC VRAA7S5 1C3F-ZC 1F719S0A10 DPC-422 216 5A07 PMT2 DIESEL 250/350 INCREASES CLUTCH PRESSURE OVER PMT1
2001 F-Series 7.3L DI TC VRAA6S3 1C3F-ZB 1F719S0A05 DPC-422 216 219C PMT1 P131 N/A
2001 F-Series 7.3L DI TC VRAA4S4 1C3F-ZA 1F719S0A00 DPC-422 216 0EEB PMT0
2001 F-Series 7.3L DI TC VRAA7P6 1C3F-AED 1F719P0B11 DPC-422 216 75FA KRK3
2001 F-Series 7.3L DI TC VRAA7P5 1C3F-AEC 1F719P0B10 DPC-422 216 76F6 KRK2 450/550 4.88 CFF/LEV P131/U137
2001 F-Series 7.3L DI TC VRAA6P3 1C3F-AEB 1F719P0B05 DPC-422 216 3F8B KRK1 P131 N/A
1999 F-Series 7.3L DI TC VJAE7U3 XU2F-RD 9DTA-AUC DPC-422 216 EF1D MRT3
2000 F-Series 7.3L DI TC VNAAAT2 XU7F-BA 0F729T0A00 DPC-422 216 LSL0 LSL0 P131 N/A
2000 F-Series 7.3L DI TC VNAB6P2 YU7F-CA 0F719P0B12 DPC-422 216 6353 HAM0 P131 N/A
2000 F-Series 7.3L DI TC VNAAAT3 XU7F-BB 0F729T0A00 DPC-422 216 216D LSL1
2000 F-Series 7.3L DI TC VNAA8U5 XC3F-BF 9DTA-AUD DPC-422 216 E6BF NVK4 P131 DIESEL/49S
2000 F-Series 7.3L DI TC VNAA9S4 XC3F-BG 0F729S0A00 DPC-422 216 01BD NVK5 ECONO F250/350
2000 F-Series 7.3L DI TC VNAAAS2 XU7F-AA 0F729S0A00 DPC-422 216 FB8F MNM0 P131 N/A
2001 F-Series 7.3L DI TC VRAA4P6 1C3F-AEA 1F719P0B00 DPC-422 216 26DD KRK0
2000 F-Series 7.3L DI TC VNAA9T4 XC3F-PG 0F729T0A00 DPC-422 216 28A4 CNH5 P131 F450/550
2000 F-Series 7.3L DI TC VNAB5P3 YC3F-BCB 0F719P0B12 DPC-422 216 6B38 YLE1 P131 CACKLE FIX
2000 F-Series 7.3L DI TC VNAAAS3 XU7F-AB 0F729S0A00 DPC-422 216 FB92 MNM1
2000 F-Series 7.3L DI TC VNAB6P3 YU7F-CB 0F719P0B12 DPC-422 216 6455 HAM1
1999 F-Series 7.3L DI TC VJAE7V3 XU2F-AAD 9DTA-AVC DPC-422 216 1209 LVS3
1999 F-Series 7.3L DI TC VJAE7S3 XU2F-ABD 9DTA-ASC DPC-422 216 0511 RXM3
1999 F-Series 7.3L DI TC VJAE7R3 XU2F-ZD 9DTA-ARC DPC-422 216 E12C YEV3
2000 F-Series 7.3L DI TC VNAB1P6 YC3F-BCA 0F719P0B11 DPC-422 216 B201 YLE0 F450/550 AUTO CFFV P131
2000 F-Series 7.3L DI TC VNAA8V7 XC3F-PF 9DTA-AVD DPC-422 216 0CA8 CNH4 P131 DIESEL/50S
1999 F-Series 7.3L DI TC VJAE5V4 XU2F-AAA 9DTA-AVC DPC-422 216 FF3B LVS0 P131 SERVICE
1999 F-Series 7.3L DI TC VJAE7S2 XU2F-ABC 9DTA-ASC DPC-422 216 050E RXM2 P131 N/A
1999 F-Series 7.3L DI TC VJAE6V4 XU2F-AAB 9DTA-AVC DPC-422 216 1610 LVS1 P131 F450/550
1999 F-Series 7.3L DI TC VJAE3V5 XC3F-EPD 9DTA-AVC DPC-422 216 9B49 CNH3 P131 50S/COLD/AUTO
1999 F-Series 7.3L DI TC VJAE3V3 XC3F-PD 9DTA-AVB DPC-422 216 A119 CNH2 PHN131 50S/AUTO/COLD
1999 F-Series 7.3L DI TC VJAE1V5 XC3F-PC 9DTA-AVA DPC-422 216 F2D1 CNH1 PHN131 50S/AUTO/COLD
1999 F-Series 7.3L DI TC VJAE0V4 XC3F-PB 9DTA-AVA DPC-422 216 8414 CNH0 F450/550/560 50S/A/T/COLD WEATHER
1999 F-Series 7.3L DI TC VJAE6U4 XU2F-RB 9DTA-AUC DPC-422 216 F225 MRT1 P131 F250/350
1999 F-Series 7.3L DI TC VJAE5U5 XU2F-RA 9DTA-AUC DPC-422 216 DB51 MRT0 P131 SERVICE
1999 F-Series 7.3L DI TC VJAE3U5 XC3F-EBD 9DTA-AUC DPC-422 216 A937 NVK3 P131 FED/COLD/AUTO
1999 F-Series 7.3L DI TC VJAE3U3 XC3F-BD 9DTA-AUB DPC-422 216 B006 NVK2 PHN131 49S/AUTO/COLD
1999 F-Series 7.3L DI TC VJAE1U4 XC3F-BC 9DTA-AUA DPC-422 216 00BE NVK1 PHN131 FED/AUTO/COLD WEATHR
1999 F-Series 7.3L DI TC VJAE0U4 XC3F-BB 9DTA-AUA DPC-422 216 9302 NVK0 F250/350 49S/A/T/COLD WEATHER
1999 F-Series 7.3L DI TC VJAE7U2 XU2F-RC 9DTA-AUC DPC-422 216 EE1A MRT2 P131 N/A
1999 F-Series 7.3L DI TC VJAE7V2 XU2F-AAC 9DTA-AVC DPC-422 216 1305 LVS2 P131 N/A
Old Aug 9, 2008 | 11:19 PM
pmbmax's Avatar
pmbmax
Thanks For the info
Old Aug 10, 2008 | 07:29 PM
portsample's Avatar
portsample
I've just bought an early '99 F350 and am currently in the process of cleaning it up and doing moderate upgrading.
So far I've swapped the original air filter out for a 6.0 style using the Ford conversion kit. I've also got (2) CPS units on order (1-swap, 1-spare).
What other upgrades make sense?
Has anyone tried the fuel rail crossover hoses?
Thanks.
Old Aug 11, 2008 | 03:04 AM
ron's power stroke
Thanks.
i think your talking about the HPX...its a high pressure cross over for the oil rails...worth doing for sure..the in tank kit called the hutch and harpoon mods are also worth doing... what are you looking for in your truck?? little better then stock?? high HP ? or some place in between?? now that you have air getting in....put a 4" exhaust on to help get the air back out...put in a set of gauges then add the DP tuner...
Old Aug 11, 2008 | 11:40 AM
portsample's Avatar
portsample
Thanks- I was thinking oil and typed fuel. I'm looking for fuel economy and overall ruggedness and reliability. I've added an oil pan heater as well as two battery plates to the existing block heater for quick winter warm-ups, (I live in Alaska). I drove it from Glennallen to Anchorage, (200 miles) w/cruise control set at 50 mph, with the old stock air filter still installed and got 21.1 mpg.
Old Dec 18, 2008 | 01:30 PM
Bigfwt04's Avatar
Bigfwt04
Question
PSD ONLY
If you get a DP does it take care of this or should anyone with an early 99 always change the PCM?
Old Dec 18, 2008 | 02:58 PM
superduty4x4's Avatar
superduty4x4
Clay, Jody is now able to tweak your early bird PCM just as good as he can the later ones, so no need to swap anymore (unless yours is a Cali, then swap because the programming on the Cali's is crap). If you decide to swap, PMT1 and PMT2 are the preferred candidates, the PMT2 has higher clutch holding pressure than the PMT1 but the 3-4 shift is quick... almost too quick. Shoot for a PMT1, but if you find a good deal on a PMT2 it's a good choice also. FWIW I have the PMT2 and I'm happy with it.
Old Dec 18, 2008 | 03:50 PM
Bigfwt04's Avatar
Bigfwt04
If it has a gpr and not a gpcm is that a definitive way to tell its not a cali truck?
Old Dec 18, 2008 | 04:21 PM
Fat Diesel's Avatar
Fat Diesel
Not on an Early 99. Mine is a CA model and has the relay, well now it has the Stancor, but it never had the module. Later ones, if they have the module, are CA trucks... I think!
Last time I talked to Jody (less than a year ago) he said the early computer is not capable of holding or processing the same amount of data and that's why you go to a later PCM.
Old Dec 18, 2008 | 04:45 PM
ron's power stroke
what Andy said..the newer PCM will make the truck run better and shift better..lot more room to play with the newer PCM..Jody has come a long way with the early 99 PCM..if all your going to do is chip your DD... i wouldnt worry about the PCM..but if your going to tow or do big mod's..change it out..
Old Dec 18, 2008 | 04:57 PM
  #28
Bigfwt04's Avatar
Bigfwt04
Question
Is the PCM what the DP plugs into? Are they completely plug and play or do you have to get them flashed first?
Old Dec 18, 2008 | 04:59 PM
  #29
ron's power stroke
plug her in and have a chip made for it...or if you already have a chip send it back for a re burn..the chip goes into the PCM..click here
http://www.dp-tuner.com/wordpress/wp...stallation.pdf
Old Dec 18, 2008 | 05:07 PM
  #30
Bigfwt04's Avatar
Bigfwt04
One more sorry How do I know which one I need on carparts-com list?
