Modular V10 (6.8l)
Rough idle after plug change
Old Aug 1, 2008 | 09:14 PM
Mr. Obvious's Avatar
Mr. Obvious
I noticed after changing my plugs and boots the Ex V10 seemed to have a little rougher idle. Before it was perfectly smooth but after I could feel a little roughness which goes away as soon as the rpm's go up. Definitely not a full miss on a cylinder.
I have seen a few other people report this on the 5.4 engine.
Any plug changers notice this on their V10? On the 5.4 they suggest disconnect the battery for a few minutes but that may or may not fix it. Definitely didn't disconnect any vacuum hoses during the change.
Any thoughts?
Old Aug 1, 2008 | 09:22 PM
sidestep's Avatar
sidestep
what year is the ford? What type of plugs did you replace it with.
Old Aug 1, 2008 | 09:30 PM
Antelope V-10's Avatar
Antelope V-10
I noticed this on my first start up after changing plugs. I attributed it to the truck sitting for almost a week without running. It has smoothed out nice though. Runs great. Did yours smooth out?
Old Aug 1, 2008 | 11:46 PM
Monster-4's Avatar
Monster-4
I had the same thing after changing my plugs. I hooked up my ODB scanner and it showed two bad COPs. Might be worth hooking one up and checking. If you don't have one take a trip down to Advanced Auto or Autozone and borrowing their scanner.
Old Aug 2, 2008 | 11:29 AM
krewat's Avatar
krewat
FTE Leadership Emeritus
What brand plugs did you use?
Old Aug 2, 2008 | 01:43 PM
Mr. Obvious
I used the recommended motorcraft plugs with the longer threads as compared to the old plugs.
The boots were from NAPA.
Would my scangauge pick up on bad cop's? I haven't had a chance to read the manual for it yet.
I have not driven it for the past week so don't know if it improved while resting in the shaded garage.
Old Aug 2, 2008 | 02:47 PM
krewat's Avatar
krewat
I think if it can read "extended" manufacturer-specific parameters, it can.
Old Aug 2, 2008 | 03:26 PM
Monster-4's Avatar
Monster-4
Looking at Scan Gauge's web site it is not clear if it will pickup pending codes are not. I know my Actron 9180 will show "mis-fires" and give the cylinder number. The mis-fires can be from several things but in my case (and a lot of cases) it was bad coils. I know Advanced Auto will loan you a Actron brand scanner and usually they will all read pending codes that will show the cylinder number that is mis-firing.
kingnothingness
2004 - 2008 F150
May 15, 2019 07:25 PM
jacksonlee5
1997 - 2003 F150
May 7, 2017 12:11 AM
ad2435
Dec 30, 2016 10:29 PM
GCosta
2004 - 2008 F150
Mar 4, 2016 09:57 AM
04150
2004 - 2008 F150
Feb 3, 2016 07:24 PM
