Hpop Problems
I ordered a rebuilt HPOP and got it in Monday. Truck ran fine, but continued to leak oil excessively. Traced it to HPOP. THought I had reuined the gasket when I installed it...Nope...
On the side of the HPOP there is a csting flaw...A small hole that goes all the way through the casting under the IPR. This is on a 97 PSD. All the other pumps I have and all pictures have NO hole in this area. This is the area where it appeared that hte oil was flowing from.
If it were not for bad luck, I'd have no luck at all. Now the Diesel service does not have another pump to replace it with.....
Has anybody ever dealt with BLUERIDGE DIESEL SERVICE in SALEM VA?
I would have hopped that the Remanufacture ofthe pump would have seen this hole and discarded the casting....
Did not notice it when I put the IPR on....when I did notice it, it looked like a casting flaw, raised area...but closer inspection showed a small hole in the flaw....
Now I am out of service for another week probably...
I wish I had the info on the reman that did the pump that started all this...
the and I'd have a serious conversation. Can't find it in my records..and that was only last summer.
But on a high note, and I know this is not a joking matter.....I do have a stock pile of gear bolts and washers if you need a spare. LOL I couldn't help myself... I hope you and your family are doing well, and I hope you get this figured out because I know it's been a thorn in your side. And honestly, if I had another pump, I'd just send it to you. Good luck man.
Cody
Thanks ...
I inspected the pump closer and it turns out somebody DRILLED a hole in the side where the main wabble pump is and then put a pop rivet in it.
This pump was remaned by Delphi and distributed by Blueridge Diesel in Salem Va.
I now know what size check ball will work. I did some measuring and determined that 0.185" diameter ball bearing may work. I got one and put it in the original pump that had the O-Ring fail and YES it workes.
The bogus pump is on its way back to where it came from. If I knew how to post a picture, I'd post one of the pump.... They had a 1 year warranty...did not argue when I sent them pictures of the hole
Most aggrivating part is that I purchased nearly $100 in gaskets O-Rings and sealer this morning thinking that was the problem.
Put the ball in the OLD pump and went ahead and used the new gaskets and installed the old pump. Primed it for about 30 seconds and it fired right up when I turned the key on.
Rubber Duck...I STILL HAVE A BAG FULL OF SPARE BOLTS.......LOL....
I did have to helicoil one of the pump bolts...I did the other one when I replaced the pump last year....Now both sides are helicoiled and will take the correct torque....
I am becomming an expert on these pumps. Out and in, in less than 1 hour....
Can nearly do it blind folded....except for that darn bolt in the gear...LOL
Thanks for chiming in...
Racenitro
Is there any advantage to putting the cross over line between the two head galleys?
I saw some information on this and was wondering if it had any advantages...If I did it, I'd use steel line, not braided so ther would be no possibility for expansion of the braided line under the high pressures.
Thanks
