I'm looking at doing stacks on my truck, and if I do, I want to wrap pretty much all the pipe inside the bed with header wrap (to keep temps down, I don't want stuff melting on them and I will have a toolbox).
Now, I would want to seal the wrap- I know DEI sells that (really expensive) header wrap sealer spray, but what's so special about it?
Could I just go with Duplicolor high temp paint there since the wrap won't be seeing as high of temps as a header would? (I would think a couple coats of that would work just fine)
Also what's the easiest way to figure out how much 4" pipe a 50' x 2" wide roll of wrap would cover?
