starter solenoid
Old Aug 30, 2002 | 05:50 PM
XJeepGuy's Avatar
XJeepGuy
starter solenoid
Old Sep 2, 2002 | 09:41 PM
Pilgrim's Avatar
Pilgrim
starter solenoid
I have a 91 Ranger 3.0 that only clicks when key is in start position. Battery is good. Relay on fender is good. Cables all seem good. Starter does not work when tested on bench with booster cables. Does not turn, nor does drive engage. Shows no problems on disassembly. Has to be the solenoid on the starter motor right? I'm planning to buy a new one tomorrow. Someone please stop me if I'm doing the wrong thing. Thanks in advance.
Old Sep 3, 2002 | 11:56 AM
Mil1ion's Avatar
Mil1ion
starter solenoid
Starter Drive on Starter is most likely the problem.
Does it really spark when you put power to it when testing?
http://www.clubfte.com/users/mil1ion/2cents.gif
[font color=red]Dennis
FTE Assistant Administrator
[/font]
[link: motorhaven.autoanything.com|How YOU Can Support This Site]
http://www.clubfte.com/users/mil1ion/canada_flag_animated.gif
[link:www.clubfte.com/users/mil1ion/Mil1ion.html|My Website,"North Of The 49th"]
[link:www.ford-trucks.com/guidelines.html|Club FTE]
http://www.clubfte.com/users/mil1ion/Minimorleytruck.JPG
[font color=blue]78 F-150 429CJ,Silver,Explorer Pkg.
64 1/2 Mustang Pre-World's Fair Car #8092
68-Mustang 289 2v-Sunlit Gold
[/font]
Old Sep 3, 2002 | 12:53 PM
Pilgrim's Avatar
Pilgrim
starter solenoid
Thanks Dennis. I had already got the new solenoid this morning and it's running now though.
Old Sep 3, 2002 | 02:06 PM
Mil1ion's Avatar
Mil1ion
starter solenoid
Going by the 1st post and now this last one.
That is confusing.
The starter *solenoid* is an electrical device on the fender.
The starter *Drive* is part of the starter.
Which part did you actually change?
[/font]
[/font]
Old Sep 3, 2002 | 07:33 PM
1968F250LWB's Avatar
1968F250LWB
starter solenoid
I thought that on the later model trucks the solonoid is actually on the starter.
Russell
1968 F250 LWB 300-6
FORD=First on Race Day
#88 Dale Jarrett
#21 Elliott Sadler
#97 Kurt Busch
#28 Ricky Rudd
Old Sep 3, 2002 | 10:42 PM
Mil1ion's Avatar
Mil1ion
starter solenoid
That's most likely the case ,Russ.
(He did state the RELAY on the fender was good).
Plus,I can't remember them all.
He still needs to explain which one he actually replaced because he mentioned the non-starter function (off the vehicle) and saying the solenoid (relay) was already checked.
[/font]
[/font]
Old Sep 3, 2002 | 11:54 PM
Pilgrim's Avatar
Pilgrim
starter solenoid
Sorry for not replying sooner, guys. I've been having trouble getting on here.? Hopefully this clarifies everything. I used the term "relay" for the solenoid on the fender because that's what the Hayne's manual I have on my desk calls it and I thought if I referred to it as the solenoid someone would reply and say "that's the thing on the starter". Anyway the "thing" on the fender was good as per the first post. The thing I consider the "drive" (the tiny gear/overrunning clutch assembly that engages the ring gear) was good. The "solenoid" on the starter (which moves the drive in and out and also contains the contacts) was bad. Replaced it. All's well now.
Old Aug 28, 2003 | 02:13 PM
thpnalb's Avatar
thpnalb
starter solenoid
FYI, Pilgrim, you are using all the right terms THIS guy understands. A relay relays current, a solenoid generally causes some mechanical linear action as a result of current in a field surrounding a moving iron core. And, I would call the over-run clutch a "drive".
But who am I to say?
