Oil Pressure Sending Unit
Old Jul 30, 2008 | 09:52 PM
cana55's Avatar
cana55
Hi folks,
I am just retrofitting dash in my 47 pickup with new modern gauges. I am using electrical style this time and I am looking to find the right sending unit for a 302 ford engine oil pressure. I assume it has some sort of pot on the end with an electrical connection. I pick one up recently at a swap meet and it has small end and a connector to slip on electrical connection and requires a special tool to tighten, but it looks more like a sending unit for an idiot light. I know there are many threads regarding the 80's and up fords using a sending unit that only represents on or off. Any feed back would be appreciated.
John
Old Jul 31, 2008 | 04:46 AM
EPNCSU2006's Avatar
EPNCSU2006
What is the gauge from? I know my 87 F150 with a 302 has a variable resistance sender, but if the gauge you have is set up for a switch, the variable resistor sender won't work quite right without modification to the gauge.
Old Jul 31, 2008 | 05:30 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by cana55
Hi folks,
I know there are many threads regarding the 80's ('80's??) and up fords using a sending unit that only represents on or off. Any feed back would be appreciated.
John
The correct one is:
E4ZZ9278A .. Oil Pressure Sending Unit-Use with Gauge-Dome Shaped (Motorcraft SW1547B)
MSRP: $33.29 / FTEpartsguy.com price: $17.98
E4ZZ9278A replaced: B7T-9278-A / C7ZZ-9278-A / C9ZZ-9278-A.
Used with all oil pressure gauges from 1957 thru 1991.
(The idiot sender [D4AZ9278A] fits 1957/2008)
Old Oct 29, 2008 | 04:51 AM
Tamecrow's Avatar
Tamecrow
"E4ZZ9278A .. Oil Pressure Sending Unit-Use with Gauge-Dome Shaped (Motorcraft SW1547B)"
What's the difference between E4ZZ9278A and E4TZ9278A? (Motorcraft SW873B). They look identical.
SageMoonblade
16
Oct 1, 2025 12:43 PM
Bib
Apr 24, 2017 04:55 AM
expedition_man
Dec 22, 2016 02:54 PM
Rocketattack
Apr 25, 2016 09:00 PM
CougarMark67XR7
May 4, 2006 08:55 PM
