Gas Tank Question
Old Apr 21, 2017 | 06:39 PM
Bib's Avatar
Bib
Gas Tank Question
Have an 87 with 302 EFI. Switching out to 84 351W carb with mech fuel pump. Is the tank in the middle of the frame same except for the sending unit?
To be a bit more clear; Can I switch out the sending unit with one for a mechanical fuel pump? I am not using the electric pump that was original to the EFI. I am looking to see if it is as simple as just installing the correct sending unit.
Thanks,
Bib
Old Apr 23, 2017 | 06:55 AM
Benztechnc's Avatar
Benztechnc
Thanks,
Bib
probably not. But I'd check tank part numbers at your favorite auto parts website.
Old Apr 23, 2017 | 06:24 PM
Bib's Avatar
Bib
Thanks for replying. Will be calling Bronco Graveyard in the morning looking for further info.
Old Apr 23, 2017 | 10:27 PM
Benztechnc's Avatar
Benztechnc
It really depends in the end on what pressures you are looking for. I don't know much about carbs but I always thought they run around 5 psi. The 87 stock should have a low pressure in tank pump to feed the high pressure pump in line. Would the low pressure in tank feed you enough to run a carb?
Id probably find an efi donor with a 351 and leave it efi, since carbs are so finicky.
Old Apr 24, 2017 | 04:55 AM
Bib's Avatar
Bib
The Edelbrock I am feeding needs 5.5, correct. I regulate that with a Edelbrock 5.5 mechanical pump. Love EFI, hate the electronics required to make them work.
RL250
Aug 22, 2014 09:54 PM
jasmine.carrigan87
1978 - 1996 Big Bronco
Jun 20, 2009 04:27 PM
weswes01
Oct 28, 2007 05:34 PM
86rustbucket
Oct 12, 2006 11:27 AM
