Air turbulence with rear windows open
Old 07-30-2008, 03:38 PM
JRROTH1's Avatar
JRROTH1
JRROTH1 is offline
I just purchased an '08 SCrew lariat the other day. Has anybody else noticed the severe turbulence created with the rear windows open in this model or is it just my truck. At 40 mph, it sounds like a helicopter (due to the air pressure changing in the cab most likely) and the entire truck vibrates as if you are driving on a washboard-type road. I may be exxagerating just a little but it is pretty bad! I don't remember my '04 SCrew doing that but I will have to check it out tonight. The dealer service writer said that it was normal for that to happen with the rear windows open.
Old 07-30-2008, 03:53 PM
roushcm's Avatar
roushcm
roushcm is offline
I experience the same thing in my 2004 SCrew Lariat at about the same speed. I never have the rears open at any higher speed so I dont know if it goes away or not. I'm pretty sure its a common thing at that speed.
Old 07-30-2008, 04:33 PM
Mauser's Avatar
Mauser
Mauser is offline
Wind noise
I have the same thing on my 06 screw. It does not matter what speed I am running. To do away with it I slide open my back glass or pop open my moon roof.
Old 07-30-2008, 05:12 PM
JRROTH1's Avatar
JRROTH1
JRROTH1 is offline
I don't have an issue with the "wind noise" Mauser - its the vibration in the entire truck that surprised me. I don't remember experiencing that in my '04' but I will give it a test later. Maybe I just never had one or both rear windows open long enough to notice since I usually have the rear slider or moon roof open when trying to get the heat out quicker.
Thanks for the information - I didn't think it was just this truck but I couldn't find any similar posts so I began to wonder . . . . . .
Old 07-30-2008, 06:25 PM
r-rat's Avatar
r-rat
r-rat is offline
I have a 05 srcew it does the same thing, just crack one of the front windows a little it should go away.
Old 07-30-2008, 07:39 PM
powerz69's Avatar
powerz69
powerz69 is offline
I had the 2 rear windows down half way a few days ago with no problems. I'll try full down next time.
Old 07-30-2008, 10:50 PM
Tylus's Avatar
Tylus
Tylus is online now
MMNC (SS)(Ret)
front windows all down
rear windows 1/2 or all down
get a horrible thumping noise/sensation that you can more feel than hear. lots of overpressure and hurts my ears
to solve:
1. open rear slider
2. only have 3 windows open (doesn't always fix problem)
3. only have fronts cracked
4. only open rears about 2-3"
5. run a/c with windows up
FYI, opening the moonroof actually makes it worse for me. and also, the Dodge/Chevies do it also.
Old 07-31-2008, 08:52 AM
adolphbell's Avatar
adolphbell
adolphbell is offline
This wind noise exists with the crew cabs. I have it in my '07 F150 and my '02 F250. I can open the sliding window in the F250 and largely eliminate the noise; my F150 doesn't have a sliding window. This is simply something you live with if you have a crew cab.
Old 07-31-2008, 09:00 AM
tucker1999's Avatar
tucker1999
tucker1999 is offline
05 F-350 crew. same thing here as well no matter what speed I am going. remedy is to just close them and have the slider open or just the front windows for me.
Old 07-31-2008, 03:12 PM
Sawsalesman's Avatar
Sawsalesman
Sawsalesman is offline
Same problem with my 04 Crew. Even my wifes Mazda 5 does it. Just crack one of the front windows and it goes away.
Old 07-31-2008, 08:13 PM
mtondreo's Avatar
mtondreo
mtondreo is offline
same here - a pain with the dog in the truck. But same remedy, crack a front window. Mine is at all speeds also.
Old 07-31-2008, 11:36 PM
bememe's Avatar
bememe
bememe is offline
I have experienced the same problem. Seems odd I never remember it occuring on my superduty. Wonder what causes it?
Old 08-01-2008, 12:19 AM
Monsta's Avatar
Monsta
Monsta is offline
Sit. Stay.
Mine went away when I added in-channel vent visors. I can now run with the back windows down without any of that noise.
Old 08-02-2008, 08:37 AM
Panzerbrumbar's Avatar
Panzerbrumbar
Panzerbrumbar is offline
My 04 Screw does the same thing still have not gotten around to fixing it. But TSB 05-14-2 addresses it, basically it is opening up your headliner just enough to install a couple of foam blocks by the interior light. Hope this helps everyone out.
gman97005
Exhaust Systems
23
02-22-2022 01:17 PM
Broughton
6.7L Power Stroke Diesel
35
02-02-2016 06:43 AM
dbuck50
2004 - 2008 F150
07-29-2015 06:58 PM
Ranger80
09-21-2014 02:20 PM
cpdorroh
2009 - 2014 F150
25
05-24-2012 03:39 PM
Quick Reply: Air turbulence with rear windows open
