Air turbulence with rear windows open
I just purchased an '08 SCrew lariat the other day. Has anybody else noticed the severe turbulence created with the rear windows open in this model or is it just my truck. At 40 mph, it sounds like a helicopter (due to the air pressure changing in the cab most likely) and the entire truck vibrates as if you are driving on a washboard-type road. I may be exxagerating just a little but it is pretty bad! I don't remember my '04 SCrew doing that but I will have to check it out tonight. The dealer service writer said that it was normal for that to happen with the rear windows open.
I don't have an issue with the "wind noise" Mauser - its the vibration in the entire truck that surprised me. I don't remember experiencing that in my '04' but I will give it a test later. Maybe I just never had one or both rear windows open long enough to notice since I usually have the rear slider or moon roof open when trying to get the heat out quicker.
Thanks for the information - I didn't think it was just this truck but I couldn't find any similar posts so I began to wonder . . . . . .
front windows all down
rear windows 1/2 or all down
get a horrible thumping noise/sensation that you can more feel than hear. lots of overpressure and hurts my ears
to solve:
1. open rear slider
2. only have 3 windows open (doesn't always fix problem)
3. only have fronts cracked
4. only open rears about 2-3"
5. run a/c with windows up
FYI, opening the moonroof actually makes it worse for me. and also, the Dodge/Chevies do it also.
to solve:
1. open rear slider
Ranger80
09-21-2014 02:20 PM
